anyone tried hondata heatshield gasket B4???
are you refering to the plastic intake manifold gasket?
Using something similar I had made (used a higher heat resistant material). Works great so far. Repeatability (due to less heat in the intake) and ease to cool are much better...
Jason
Jason
I've only test-fitted mine and all I can say is that I need to dremel out a couple of the stud holes and also a few places along the ports.
yah i know most of my friends from da ALL MOTOR GROUP in new zealand are using hondata head gasket but they are using da race type....da one u have to run ur coolant hoses or sumthin to make da intake manifold more cooler. also u have to modify da thermostat(drill 6 holes). i dont know sounds complicated.....i juss wanted some feed back from da guys in da states.
huevosrancheros
Oct 14, 2006 09:33 AM
PrecisionH23a
Sep 19, 2004 07:38 PM
