Heater Problem...
Old Sep 22, 2009 | 08:43 PM
NAturalEk9's Avatar
Default Heater Problem...
i have a 94 Acura Integra LS and i just replaced my climate control with a Gsr Climate Control cause my old one was broken and everytime i try to turn on the heat i get no response the only thing that is working on my climate control is my Hazards, the blower motor still works cause i tesed it but it wont turn on whenever i try to turn on the heat.
Old Sep 23, 2009 | 06:09 AM
fcm's Avatar
fcm
Old Fart
Default Re: Heater Problem...
Check blower motor resistor pack. 94
Old Sep 30, 2009 | 10:52 AM
NAturalEk9's Avatar
hmm i change the blower motor resistor pack still nothing....
Old Sep 30, 2009 | 04:53 PM
fcm's Avatar
fcm
Old Fart
How did you test the blower motor? 94
Old Oct 2, 2009 | 05:54 PM
NAturalEk9's Avatar
i hooked up 2 wires to it and hooked it up to the battery and it came on
Old Oct 5, 2009 | 03:42 AM
fcm's Avatar
fcm
Old Fart
Have you checked to see if there is power at the blower motor? 94
Old Oct 5, 2009 | 04:53 PM
NAturalEk9's Avatar
hmm no not yet i dont have a volt meter but what if there is? what else could it be?
Old Oct 6, 2009 | 11:55 AM
fcm's Avatar
fcm
Old Fart
If the blower motor works, [power and ground direct] then either it's not getting power or ground through stock wiring.
You do not need a meter to check, use the power and ground jumpers you used to test the motor, leave the stock harness plugged in to the motor, then shove the ground jumper into the ground side of plug, turn ign. on if blower works it has power and the problem is on the ground side, [control head, blower resistor or wiring/connections] if blower does not work, remove ground jumper and shove power jumper into power side of blower motor plug, turn blower switch on, [test all speeds] if blower works the problem is the power side, [fuse, blower relay if used, 2nd ign. circuit of ign. switch or wiring/connections.
You need to determine if the problem is on the power or ground side of circuit, checking the blower motor itself is the first thing, next is which side of circuit. 94
slowesteg
Honda CR-V & Element
Jul 1, 2013 07:04 PM
94trouble
Nov 11, 2010 05:50 AM
92siegcivickid
Sep 17, 2010 10:47 AM
Dbach
Nov 12, 2008 12:01 PM
VTECisSeXY
Jan 14, 2005 04:10 AM
