Suspension & Brakes Theory, alignment, spring rates....
Function 7 lca and endlink ?
Old Sep 22, 2009 | 06:49 PM
ivicr's Avatar
Default Function 7 lca and endlink ?
Ive got the function 7 lca's on my eh2(eg6), and im putting a gs-r rear anti-roll bar(sway) on. upon attching the endlinks to the lca's, there are 3 holes in which to attach the endlinks too. If i get the adjustable endlinks, what is the difference on where you place the endlinks too ?
Old Sep 22, 2009 | 08:29 PM
Egezzy's Avatar
Spongebrad Squarepants
Default Re: Function 7 lca and endlink ?
given the same adjusted length it would be stiffness or the arb rate.
Old Sep 23, 2009 | 05:52 AM
ivicr's Avatar
which setting would be the stiffest and which wouldn't ?
Old Sep 23, 2009 | 10:50 AM
DavidR's Avatar
The softest setting is the inside, center is closest to stock, and the outside is the "hardest".
Old Sep 23, 2009 | 11:43 AM
ivicr's Avatar
Thanks @!
Old Sep 30, 2009 | 03:12 PM
Function7's Avatar
The holes are marked: H = hard, M = medium (closest to stock), S = soft.
The stiffness changes by about 10% going from hole to hole (i.e. each step).
EsQueue
Suspension & Brakes
Jan 11, 2006 10:27 PM
LaOstha
Aug 20, 2005 10:29 AM
spyz34
Jan 29, 2005 10:37 PM
clm
10
Aug 23, 2003 01:35 PM
wickedxboi
Jan 29, 2003 10:50 PM
