02 accord 4cyl fuel system service question
Old Sep 22, 2009 | 03:53 PM
pinoy2o9's Avatar
Default 02 accord 4cyl fuel system service question
what needs to be done? my car has 144k now. and i just got it serviced for oil and they said it needs a fuel system service. thanks in advanced.
Old Sep 22, 2009 | 07:21 PM
phootbag's Avatar
Default Re: 02 accord 4cyl fuel system service question
Hondas are never "due" for a fuel system service. Most likely their shop is due for your fuel system service. I have never changed a fuel filter due to a drivability symptom. Even on neglected vehicles.
Old Sep 22, 2009 | 07:54 PM
pinoy2o9's Avatar
thanks. looks like you work for honda. much appreciated.
would those fuel cleaners and octane things work?
Old Sep 23, 2009 | 03:11 AM
hondamark35's Avatar
maybe, but it won't change the way the car drives.
fuel coming from the injectors does a pretty good job of keeping the area of the ports it contacts clean.
best thing you can do without taking the motor appart... is to clean the TB with carb cleaner and continue to maintain the oil and the ignition system. (these two things seem to have the most severe impact on drivability when they are neglected)
Old Sep 23, 2009 | 10:06 AM
P_Adams's Avatar
There's not much to service... a can of injector cleaner and the winter shot of dry gas should pretty much cover it.
Starting in 1998, even the fuel filter was buried in the tank, never to see the light of day again.
The only thing which might come to mind would be to inspect the air cleaner element and clean the throttle body bore. (both very easy)
P
SteveT2008
32
Jul 15, 2015 06:25 PM
Mattyg2
Apr 13, 2004 06:15 PM
turrismaldon
Oct 24, 2002 03:28 PM
91BlackAccord
May 13, 2002 01:07 PM
