High idling on a b18c5
Old Sep 22, 2009 | 08:07 AM
hialeahzbg's Avatar
Default High idling on a b18c5
I have a 93 civic with a obd2 ITR swap.. My car idles around 1400 and randomly jumps to 2000... Today I swapped out the iacv and it still does the same thing... I'm using a Jdm p30 with the swap... Can anyone help me?
Old Sep 22, 2009 | 08:18 AM
hialeahzbg's Avatar
Default Re: High idling on a b18c5
Do b18c5 swaps have fitv? If so where? My throttle body doesn't have anything..
Old Sep 22, 2009 | 11:15 AM
hialeahzbg's Avatar
Anyone?
Old Sep 22, 2009 | 11:44 AM
Mashimaro's Avatar
you may have a vacuum leak if you're jumping idle like that.
get a bottle of brake cleaner, start the car and start spraying around the intake manifold. if the idle drops over certain areas you sprayed, then you know where the leak is around.
Old Sep 22, 2009 | 01:56 PM
hialeahzbg's Avatar
Around the intake manifold gasket?
Old Sep 22, 2009 | 02:02 PM
Former User's Avatar
Can you kill the idling engine by covering the top of the throttle body with your hand? If not, you have a major intake air or vacuum leak.
Is the CEL on? Does the idle speed change if you unplug the IACV? Have you tried bleeding the cooling system?
Old Sep 22, 2009 | 04:58 PM
hialeahzbg's Avatar
So I cover the throttle body up with my hand or that little metal hose on the top? If it's the little metal hose ur talking about it's got a cover on it... There's no cel and I replaces the iacv today and still nothing... If I unplug he iacv what's it suppose to do?
Old Sep 23, 2009 | 06:53 AM
hialeahzbg's Avatar
I unplugged the iacv and it doesn't change..Cooling system has been changed
Old Sep 23, 2009 | 06:58 AM
Pull off the air intake to expose the throttle body. With the engine idling, cover the top of the throttle body (TB) with your hand. If the engine doesn't die, you have a major intake air/vacuum leak. Check for disconnected vacuum hoses attached to the intake manifold (IM) and leaking TB and IM gaskets.
Old Sep 23, 2009 | 11:42 AM
hialeahzbg's Avatar
Ok I'll try this as soon as I get outta work...so if it doesn't die check all the vacuum hoses and IM gasket? I just changed the tb gasket so that's okay...
Old Sep 23, 2009 | 12:18 PM
Yes, and make sure the IM and TB bolts are torqued to spec.
Old Sep 23, 2009 | 02:19 PM
hialeahzbg's Avatar
ok will do...man u are one of the most helpful person on hondatech... Ok I tried to take offthe intake while at work but the screwdriver I had wasn't long enough so I couldn't turn it... I started the car and it idled at 900 rpms?! That's weird because I wasn't able to do anything...
Old Sep 28, 2009 | 06:13 AM
hialeahzbg's Avatar
Anything else..
b16egg
Oct 26, 2011 09:31 AM
thewrai6th
Sep 13, 2011 05:19 PM
Gho$t
Nov 10, 2009 10:26 PM
DeCoY
Apr 3, 2007 03:07 PM
ridin98civic
10
Feb 2, 2007 11:11 AM
