cleaning out garage b series
please bump
.50 Trim Turbo No shaft Play .63AR Unknown brand NOT EBAY $140
Skunk2 pro gsr intake manifold $180 SOLD
Exedy stage2 clutch $140
B series log manifold $100
jdm p72 ecu $100
Blox manuel boost controller $40 SOLD
DC climate control $40
DC USDM center console and shift boot $40
GSR front and rear seats $160 for the set
P72 oil pan $40
Tapped P72 oil pan $20
GSR stock fuel rail $20
P72 oil pump 40k $20 SOLD
Air/Fuel gauge $10
Oil return pump $200
Reducer couplers $5 each 4 to 3.5" and 3.5 to 3"
2 geeksquad 8ft hdmi cables, 1 8ft hdmi to dvi cable and 1 terk 3 port hdmi switch $30 each
P72 crank pistons and rods $200
p72 flywheel, clutch and pressure plate 40k $60
b series B&M fuel regulator $40
gsr throttle body with sensors $80
b series shift linkage with no name short shifter $60
jdm p72 ecu $100
P72 oil pan $40
Air/Fuel gauge $10
