B20B/Z and B18A/B oil squirters....anyone have a pic of this install?
Old Aug 27, 2002 | 11:12 PM
riceboy's Avatar
Default B20B/Z and B18A/B oil squirters....anyone have a pic of this install?
Ummmm, my question is the title.
Old Aug 28, 2002 | 12:41 AM
Westrock2000's Avatar
Default Re: B20B/Z and B18A/B oil squirters....anyone have a pic of this install? (riceboy)
I'm also wondering about this. Like how much, probably from a dealer, and where do they go and connect to.
Old Aug 28, 2002 | 03:24 AM
Civic1992DX's Avatar
I have a few pics where they go on GSR motor. If interested, e-mail me.
Yuri K
Old Sep 4, 2002 | 12:00 AM
riceboy's Avatar
Default Re: B20B/Z and B18A/B oil squirters....anyone have a pic of this install? (Civic1992DX)
I've seen them on a VTEC motor, I know wheree they should be positioned, I'm talking about the quality of the install on the non VTEC blocks, the B18A1 has the rear oil passage indented into the inside of the crank case, on the VTEC blocks it is a flat surface, making for flush mounting, but not on the LS block, I am just interested in some pics (if there is any) of a quality install of these.
Old Sep 4, 2002 | 06:16 AM
FrostyDC4's Avatar
"Haters Gonna Hate"
25 Year Member
Old Sep 4, 2002 | 10:55 AM
acura_typer's Avatar
Banned
I have them installed on my B20. I had a friend drill the holes and then mill a flat surface on the galley for them. I also used a sealing copper washer. Make sure if you have them drilled, to drill them closest to the flywheel side of each cylinder. Mine were drilled a little bit too close, and the rod almost hit some of them. To make sure that didn't happen, I took some of the bolt heads off with a grinder, now I have about 1/8" clearence.
Use a size J bit, and a 8x.75 tap to tap the holes. get the block cleaned afterwards, you will have shavings everywhere.
slo_crx
Sep 29, 2006 02:46 PM
spoon23_JDizM AkA SpOoN20
Oct 6, 2005 05:01 PM
evolve
Jul 2, 2003 09:08 PM
under_psi
Jun 27, 2002 10:58 AM
