ECU Testing questions
Old Aug 27, 2002 | 11:09 PM
_Endless_'s Avatar
Default ECU Testing questions
i saw one shop manual where you can test each sensors in the engine. there are some measurement which involves certain measurements between the sensor and a pin on the ECU. The shop manual used a PGM-FI Test Harness. i was wondering if you can test it without the PGM-FI Test Harness. Will the ECU get damage if you don't use one and just stick a probe where a wire would come out of the socket? where can this harness be purchase?
Thanks.
Old Aug 28, 2002 | 05:55 PM
_Endless_'s Avatar
Default Re: ECU Testing questions (_Endless_)
anyone????
Old Aug 28, 2002 | 06:10 PM
BreakStuff's Avatar
New User
The test harness is used to test ecu circuits without having to "backprobe" or stick wires with the testing device.
You can get by without a test harness but make sure to clean up after testing which includes..
repair any broken/damaged connections, and use a sealant to cover pinholes to prevent moisture from doing anymore damage down the road...
holmesnmanny
Dec 18, 2011 12:51 PM
raffaelli
Oct 6, 2010 09:02 PM
ayavner
May 28, 2008 07:20 PM
Dingo68
Mar 25, 2007 05:32 PM
kanzenr91si
Nov 19, 2003 09:26 PM
