GARAGE SALE! NEUSPEED GOLDEN EAGLE AEM MSD FAL GSR HEAD BLOCK P72 P28
I HAVE A WHOLE LOT OF STUFF IM TRYING TO GET RID OF ASAP.
I HAVE 9 ECUS
3 P72'S
P28
P73
P13
P06
P2N
P2P
*newly added* obd1 complete JDM H22A swap with ported cylinder head. skunk2 valvetrain and skunk2 stage2 cams. skunk2 cam gears skunk2 pro intake manifold, driveshaft shop stage 1 pass. side axle, 90-93 accord intermediate shaft with dc driver axle, complete engine harness removed and wired to work in obd2a 96-98 civic and exedy clutch and flywheel 2900 complete
*newly added* obd2a to obd1 ecu conversion harness 80
*newly added* 3 intermediate shafts: 90-93 da b-series, 94-01 dc b-series, 90-93 accord h-series
*newly added* INLINE PRO T3 B-SERIES TURBO KIT WITH PRECISION TURBO: The B-Series turbo kit is a classic kit that has been around for years, and proven to perform efficiently. With the T3 manifold, it will allow you to retain A/C and powersteering, but stilll be able to produce up to 400-450whp with the proper setup. Using a the only cast stainless steel manifold on the market durability is not an issue to worry about. 2.5" polished aluminum charge pipes mates to a 600hp intercooler with minimum modifications.
InlinePRO T3/T4 manifold
InlinePRO charge pipes
InlinePRO 2.5" downpipe
InlinePRO 600 hp intercooler
Precision turbo ( turbo sizes will vary )
tial 38mm wastegate
brand new kit retails for 3,995.00 im looking to get 2,495.00 for everything i mean everything to make 500 whp
I HAVE A 10'' SUB WITH SUB BOX 14'' SQUARE BOX
VACUUM BOX
GREDDY E-MANAGE BRAND NEW IN BOX
EG JDM YELLOW FOG LIGHTS FACTORY 2 PIN HONDA PLUG
MSD SPORT COMPACT IGNITION WITH HARNESS
2 MSD BLASTER SS COILS
94-2001 INTEGRA ALTEZZA TAILLIGHTS
96-98 EK HATCH HEADLIGHTS
10'' SLIM LINE ELECTRIC FAN
CRACK SLEEVE OBD1 GSR BLOCK B18C1
GSR HEAD BARE WITH ALL TYPE R VALVES AND DUAL SPRING VALVETRAIN IN A BOX
OBD2 B16 INTAKE MANIFOLD W/ TB AND SENSORS
NEUSPEED YELLOW RACE COILS FOR 92-2000 CIVIC 94-01 INTEGRA
NEUSPEED FRON UPPER STRUT BAR
MUGEN B-SERIES VALVE COVER BLUE
MOROSO BATTERY BOX BLUE
OIL FILTER RELOCATION KIT BRAND NEW IN BOX MOUNT FILTER TO FIREWALL
2 SETS OF ARP EXTENDED WHEEL STUDS 1 SET BRAND NEW IN BOX
2 SETS OF ARP HEADSTUDS B-SERIES VTEC 1 SET BRAND NEW IN BOX
ARP MAIN STUDS BRAND NEW IN BOX
3 2.5'' AEM AIR FILTERS
HONDATA I.M. GASKET GSR HEAD
2 SERIES GSR OIL PUMPS
D16Y8 THROTTLE BODY AND ALTERNATOR
40 FT. PLUS 2 AND 0 GAUGE POWER WIRE WITH 4 80 AMP INLINE FUSES
B SERIES GAM GEARS STOCK GSR
GOLDEN EAGLE LS/VTEC KIT
-4 TURBO OIL FEED LINE
PLX M-300 WITH 1 WIDEBAND
I DUNNO WHY H-T WILL ONLY LET ME UPLOAD 5 FILES SO I GUESS EMAIL ME AND ILL SEND YOU PICTURES OF WHICHEVER ITEM YOURE INTERESTED IN THANKS.
SHAUN
ONEPOINTEIGHTEF@HOTMAIL.COM
I HAVE 9 ECUS
3 P72'S
P28
P73
P13
P06
P2N
P2P
tial 38mm wastegate
VACUUM BOX
SHAUN
the head studs, wheel studs, or main studs? the head studs are for a gsr motor, they wont fit an ls motor. the mains are for a gsr also, and wont fit an ls, but the wheel studs will fit any honda hub.
to the top. thanks for the views guys if you dont mind after looking through the stuff if you dont mind bump it up so i can keep the list towards the top theres so many threads lol
TealCivic115
Feb 13, 2012 12:24 PM
nvmyb20hatch
Northeast (Sales)
15
Oct 9, 2009 08:48 PM
Evolsport
Dec 16, 2002 05:19 PM
