will a 96 integra automatic engine harness work in a manual 96 integra?
is there any way to convert it? and i have a harness that ive been sleeving and shrink wrapping...but i guess it has a ckf plug and a second 02 sensor plug....so it has 4 plugs that plug into the firewall plugs instead of the three that the firewall accepts. i have a 93 civic with a 96 b18b swap and its wired for vtec...and i want to wire it for just regular b18b and i havent found any harness expet these two. any sugestions would be appreciated
find the plugs you don't need, open up the plastic and sleeving on the harness, and remove the unnecessary wires.
If you remove only the plugs/wiring from circuits that aren't needed with your ecu, like the auto tranny stuff, you won't have any codes.
I don't know if the tranny wiring has it's own plug for the body harness or not. If those unneeded wires go into a larger plug that has other wiring, then sure you might as well de-pin them.
hondacurious
Nov 12, 2013 01:14 AM
1nsoman1ac
10
Sep 22, 2009 01:08 PM
nello a.
Dec 24, 2008 12:20 AM
