Shifter feel still sucks!
Old Sep 21, 2009 | 02:23 PM
JDMPR's Avatar
Default Shifter feel still sucks!
I decided to put new shifter bushings on cause I got tired of all the play I had and not knowing what gear I was in by looking at the shifter. After I finished I noticed that it still sucks! Its still doing the same thing, I can get underneath the car with it in gear and and move the shift linkage side to side, could this be something to do with the tranny or where the short shifter sits?
Old Sep 21, 2009 | 02:27 PM
dephtone's Avatar
Default Re: Shifter feel still sucks!
Check the linkage, look for the pin that is in the linkage that connects to the trans. If someone put a nut and bolt in there for easy removal, this is why the linkage is sloppy.
Also check to make sure the stablizer, the one with the concave washer, make sure that is the proper bolt and the washer is on there correctly, this will also cause sloppy linkage.
Old Sep 21, 2009 | 03:06 PM
JDMPR's Avatar
Where the bitch pin goes there is a nut and bolt for easy removal, how would that effect anything? How does that work?
Old Sep 21, 2009 | 03:27 PM
patriot's Avatar
The bot wont be in there nearly as tight as the roll pins would be so that little bit of slop translates to a lot at the end of a 5" shifter.
Old Sep 21, 2009 | 04:06 PM
beansandrice's Avatar
All the play comes from either not having the spring pin in the coupler, the ball seat, or the Joint bushings wearing out.
Old Sep 21, 2009 | 05:43 PM
JDMPR's Avatar
Is that pin dealer only, or can I go to any parts store?
Old Sep 21, 2009 | 06:11 PM
I am not sure but I think it is a #7 spring Pin. BUT! I always get them at the Parts Dealer. Like 5 bux.
WeakSauceEJ8
Sep 15, 2011 03:38 PM
jdmkris
Jan 14, 2010 03:08 PM
Axle Raynes
Jul 15, 2009 06:54 AM
hondaPINK
17
May 17, 2006 06:09 PM
90Integra
Apr 25, 2005 08:47 PM
