94 Dome light issues (need help)
Old Sep 21, 2009 | 02:04 PM
dj_5's Avatar
New User
Default 94 Dome light issues (need help)
I bought a 94 Honda civic and my dome light isnt working nor does it beep when the door is open and key is in the ignition. Its a DX model so its all manual no aftermarket keyless entry or anything like that. I pulled the switch off at the roof and everything looks to be par. I cant find out what the problem is. From what I have researched there isnt a dome fuse and have checked all of the fuses in the panel and everything is fine. The only thing I know put on the far that is not factory is HID headlights that the previous owner has installed. I have bought new bulbs, replaced fuses, done all that I know to do and still no luck. Does anyone else know anything else I can try on this car.
Things I have seen in other posts about this subject is:
will switch work if you switch to on?
No..
Does trunk dome work?
Used to when I fist bought the car now it doesnt.
Keyless entry wired wrong?
No keyless..
Maybe some of that will help idk..
Old Sep 21, 2009 | 06:32 PM
dj_5's Avatar
New User
Default Re: 94 Dome light issues (need help)
No help???
Someone has to have something for me?
Old Sep 21, 2009 | 07:43 PM
Former User's Avatar
Dome light, trunk light, and key-on reminder - Replace 7.5A fuse #3 under the dash with a known good fuse.
Old Sep 21, 2009 | 08:21 PM
Linked's Avatar
thats completely awesome ron, now i know why we are always on your dick
Old Sep 21, 2009 | 09:07 PM
earlylocks's Avatar
if that don't do it then pull out a volt meter and start checking for continuity, could be a shorted/ open wire!
user 8508202243
Apr 29, 2012 03:33 PM
--ej1-Marie
14
Aug 23, 2011 03:02 PM
lpdrumer
Feb 20, 2011 04:25 PM
johnls
Feb 23, 2010 03:55 PM
egjake
10
Mar 30, 2009 01:18 PM
