brake causing bad idle
Old Sep 21, 2009 | 12:42 PM
project91crxsi's Avatar
Default brake causing bad idle
my idle is really bouncy and i only notice at stop signs. so i put it in neutral in a flat parking lot with the ebrake off and my foot off the brake. the idle stayed steady, as soon as i touched the pedal it would start jumping again then i let off and it stays steady again. what is causing this? also if i back out of my driveway and hold the brake it when i let off the ebrake then let go and near the bottom i push in the brake again it wont work good at all.
Old Sep 21, 2009 | 12:48 PM
mitsubishiv5's Avatar
Default Re: brake causing bad idle
im pretty sure you either have a vaccum leak at the brake booster, or your brake master cylinder is leaking fluid.
Old Sep 21, 2009 | 01:16 PM
is the master cylinder or the booster the one right up at the right near the back of the engine bay?
Old Sep 21, 2009 | 01:19 PM
90RENOsedan's Avatar
www.honda-tech.com/showthread.php?t=1160671
heres a reference
Old Sep 21, 2009 | 01:20 PM
both of them are on your fire wall. the big black thing is the booster, which creates vacuum, and the master cylinder has liquid in it, its supposed to disperse fluid to all parts of the braking system. if its leaking around where it meets the booster, its faulty, or loose.
Old Sep 21, 2009 | 01:21 PM
it would help but the pics arent working for me haha
Old Sep 21, 2009 | 01:22 PM
right side of engine bay towards the back.
Old Sep 21, 2009 | 01:26 PM
Old Sep 21, 2009 | 01:47 PM
thanks how do i check them? i checked the brake fluid in the master cylinder and its on max so it probably isnt leaking, checked the vac hose that goes to the booster and it didnt have any holes or sign of wear, looks like it was recently replaced.
Old Sep 21, 2009 | 02:26 PM
also my brake pedal seems very stiff if that helps
Old Sep 21, 2009 | 04:54 PM
any ideas? also when i backed down my driveway i noticed when let out the ebrake and held in the brake then rolled backwards with the brake not all the way out and pushed it in more to slow down alot it didnt make much of a difference the more i pushed it in it didnt really slow down
Randysi
26
Jul 26, 2012 03:28 AM
boarding2008
Jul 4, 2010 12:08 PM
Coomer
May 21, 2008 04:39 PM
snoop_bealybob
Oct 18, 2002 04:49 AM
