who makes 101mm crank for B-series?
Old Sep 21, 2009 | 12:13 PM
092eg6's Avatar
Default who makes 101mm crank for B-series?
just wanted to know
thanks
Old Sep 21, 2009 | 12:57 PM
non-VTEC's Avatar
Default Re: who makes 101mm crank for B-series?
i don't think you can fit that long of a stroke crank into a b-series block.....95mm from eagle/crower would be the most....someone else can shed some light on this?
Old Sep 21, 2009 | 01:53 PM
Top Ramen's Avatar
I know several companies (like Crower and Brian's new company) can make custom cranks, but I don't think that will work, even if you notch the block pretty severely. You could call Brian Crower and ask him how big you can go with a B series.
Old Sep 21, 2009 | 02:48 PM
D.Jones's Avatar
Since you don't often hear bigger than 95mm for the b-series, that is probably the most you can/should run... Just my opinion...But it doesn't hurt to call and get an actual reason from him right? (good question) let us know actually. kinda interested now.
Old Sep 21, 2009 | 03:42 PM
lohatch's Avatar
i think there have been some bseries engines built with 102mm strokes.
castillos maybe?
idk if they are taking 95mm cranks and welding them up and offset grinding them or what.
Old Sep 21, 2009 | 07:03 PM
jdmoutlaw's Avatar
You can buy off the shelf a 97mm crank for B and 101-102 have been used in pro AM with a B coustom made
Old Sep 21, 2009 | 10:33 PM
dragallmotor24's Avatar
I think Ericks racing made a custom crank and ran a 101mm crank for the black coupe. I would ask him.
Old Sep 22, 2009 | 08:36 AM
092eg6's Avatar
a old school guy here in town is currently doing a 101 stroke B series, so im sure the 101 can be done. I dont kno the guy too well, so i didn't want to ask him where he get that 101 crank from. 95 is the most common stroker kit there is for the B series, and i have a 95 stroker B running in the Street Power class, which has no competition against the k guys, so im thinking about the 101 set-up before i step into the K's.
Old Sep 22, 2009 | 08:38 AM
092eg6's Avatar
erick runs a 85x95 crower crank, i know ericks set-up oh too wel because my set-up is identical to his.
Old Sep 22, 2009 | 09:24 AM
4piston's Avatar
Use the 97mm Scat crank. You don't have to work real hard to get it in the block and that is pushing it for a stock deck. You will have a lot of bearing and ring maintenance with a 101 stroke, but if you like taking motors apart every 10 passes then have at it At minimum a half inch deck plate should be used, but I wouldn't even mess with that.
At the point you are spending this kind of money and pushing things this hard, why not just run an H22, SOHC F, or K24 and get away from the dimensionally handicapped B series? It will save you a lot of money in the end and you willl make more power. You can sneeze on those larger motors and more power than a B series that needs weekly maintenance.
Old Sep 22, 2009 | 09:36 AM
Trooper's Avatar
I have a set of brand new Arias Pistons set up for a 98 mm Deck Plate Engine if your intersted. I would also talk to Castillos to see what they can do.
Old Sep 22, 2009 | 11:36 AM
1.5Slowmatic's Avatar
werd. F and H motors are gettin cheap as shot to buy and build now and are better in pretty much everyway when correctly worked on than a B series
Old Sep 22, 2009 | 01:28 PM
92TypeR's Avatar
FSAE
VTECJUN ran a 98mm crank on his 14:1 methanol motor.
I don't remember who made it.
Old Sep 22, 2009 | 03:13 PM
2fastGSR's Avatar
King of the One Liners
Inline Pro has a 98mm B series crank in stock
Old Sep 22, 2009 | 06:00 PM
PyroProblem's Avatar
Anything more than 95mm an you probably are gonna wanna run a deckplate...
I know Scat offers a 98mm crank, but you are talking about serious money and serious machine work...
Old Dec 11, 2016 | 04:46 PM
vteczone's Avatar
i know this is old thread. but ericks didnt have 85x95 when he ran 9.99sec. same goes with leslie durst's crx that ran 9sec.
Old Dec 12, 2016 | 10:23 AM
TheShodan's Avatar
Moderator
Thank you for the update of information. Since this is older now, we're going to call this a WRAP!
redboost10
Feb 8, 2006 02:58 PM
d16dcoe45
Dec 1, 2005 12:57 PM
