Cam cap question
Old Sep 21, 2009 | 11:59 AM
supaslowdx's Avatar
Default Cam cap question
I have a question for those who have more experience.
First of all, I know that each head has its matched cam caps from the factory.
I want to know if you can maybe have a new set of caps aling-bored to match the head?
If so, what is the process for this? What exactly needs to happen?
Thanks for any and all contributions.
Old Sep 21, 2009 | 09:31 PM
Scott_Tucker's Avatar
Default Re: Cam cap question
Yes, it can be done. It just depends if the machine shop is equipped with both the equipment and qualified personnel.
Basically you grind a little off the mating surface of the caps to close up the bore then you line hone it back to the original diameter.
Old Sep 22, 2009 | 05:36 AM
srmofo's Avatar
what he said....unfurtunately though most of the time the process usually cost more than the head is worth unless it has some machine work already done to it, or you know someone that does it for a living. This is twice as true when its a DOHC because they have to do twice as much.
Old Sep 24, 2009 | 08:57 AM
supaslowdx's Avatar
Thanks for the info guys.
Exactly what I expected just wanted to make sure.
I have a friend that owns a machine shop so Im good to go.
Thanks again
dc2much
Jan 10, 2010 06:03 PM
gutted-dx
Dec 23, 2008 07:26 PM
ImaHondaLover
Jan 29, 2008 12:21 PM
crispy93
Mar 8, 2007 07:17 PM
