Transmission & Drivetrain Gearboxes, Differentials, Clutches
finding/ordering b16 ys1 dipstick? and using synromesh?
Old Sep 21, 2009 | 10:52 AM
xSteve_Ox's Avatar
Default finding/ordering b16 ys1 dipstick? and using synromesh?
when i got my car the trans had no dipstick it had a rubber cap on it... are all b series trans dipsticks the same? as in go to a junkyard and pull one from a ls? if not what would i order one for?? 96 97 sol si? em1?? reason being i am starting to get a 5th gear grind and want to swithc to syncro mesh. is there any difference between the gm stuff and non gm? capacity for a ys1? sorry, i would search all this but im posting from my phone cuz im in a bind and cant get to a computer.
Old Sep 21, 2009 | 11:03 AM
srmofo's Avatar
Default Re: finding/ordering b16 ys1 dipstick? and using synromesh?
wait,wat? either im reading this wrong or im confused....is this an automatic...if so those dont take mtf or syncromesh.....they use ATF z1......if this a manual you can use sycromesh, but they dont have a dipstick
Old Sep 21, 2009 | 02:51 PM
xSteve_Ox's Avatar
umm? well i stated that i have a slight 5TH GEAR grind so yes it is a 5spd. And your goin to try and tell me that it dosent have a dipstick?? Well what is this hole in my trans covered by a freakin spark plug boot (removed for pic lol). hmm oddly it looks the same as my friends d16's trans dipstick hole thats... a 5spd
I just need to know if the sticks are interchangeable between b series motors or does it have to specifically be for a b16 ys1 cable trans (has hydro internals if it makes a dif...) not sure of the year either. I'm about to do some more research on the whole syncromesh thing but any tips/suggestions/experiences would be very helpful.
[IMG][/IMG]
Old Sep 21, 2009 | 05:01 PM
srmofo's Avatar
no dude thats not a dipstick hole, its a vent. theres supposed to be a little black cover over it that keeps dirt and water out, but allows air in/out.
And you also said it has a dipstick, so thats why I was a little confused on what you were asking because MANUAL TRANS DO NOT HAVE DIPSTICKS
since you seem to be a know-it-all that doesnt know much
skip to page 4
http://techinfo.honda.com/rjanisis/p...404O00225A.pdf
You just fill MANUAL trans up until it runs out of the fill hole.
Old Sep 21, 2009 | 05:27 PM
fourthgenhatchB17's Avatar
True
and make sure the car is level when refilling.
Old Sep 21, 2009 | 07:39 PM
xSteve_Ox's Avatar
Okay, the reason I figured one went there, was my dad looked over the car after I bought it and said "need to get a dipstick for the trans", I thought he knew what the hell he was talking about due to owning a ridiculous amount of cars of all kinds, guess not. lol personally I've owned 1 other car which was auto so I haven't had much experience working/servicing a manual. Thank you for aiding in my learning curve, appreciate the help. (And yes the boot is still on there its just off for the pic.)
Old Sep 21, 2009 | 07:54 PM
Aquafina's Avatar
Oh man, this is almost as good as stuck in the basement.
Old Sep 22, 2009 | 11:35 AM
stevenDAtegra's Avatar
Also, there is no B16 YS1. Most YS1's are LS transmissions and the other few are 92-93 GSR transmissions. They're pretty close to a b16 tranny though compared to the hydraulic GSR's. Do you know what your rpm is around 50 mph in 5th? If it's the GSR tranny, it'd be around 2500-2700 I'd suspect.
Old Sep 22, 2009 | 03:40 PM
Aquafina's Avatar
RPM in 5th is not a good way to check. Too many trannys have been split open.
Old Sep 23, 2009 | 06:09 AM
irev210's Avatar
B16 YS1 "XSI/RSI" JDM trannies are everywhere
They are pretty close the the 92-00 b16 hydro trannies, but the YS1 USDM GSR or JDM YS1 B16A trannies have a shorter 1st and 5th gear.
Same 2/3/4 though.
Old Sep 23, 2009 | 04:33 PM
Aquafina's Avatar
Nope. All B series 1st gears are the same ratio.
Old Sep 23, 2009 | 05:48 PM
Mista Bone's Avatar
D Tranny Guru
psst, wrong answer
90-91 USDM B series LS/GS/RS
1st - 3.166
2nd - 1.857
3rd - 1.259
4th - 0.935
5th - 0.742
Stock FD - 4.4
92-93 USDM B series LS/GS/RS
1st - 3.23
2nd - 1.9
3rd - 1.269
4th - 0.966
5th - 0.742
Stock FD - 4.266
Also a 3.307 1st somewhere too,
Old Sep 23, 2009 | 06:29 PM
Aquafina's Avatar
Correct. Just went out and counted a 90 and 93 LS. I need to put that list together, only been 2 weeks since I said I would.
Old Sep 23, 2009 | 08:32 PM
Honda Bull's Avatar
92-93 USDM GSR and 90-93 JDM RSi/XSi. Labeled S1, J1, or YS1. But we all know that the cable trans are all misleading. lol Damn Y1 is the only honest one. :p
C_Rock77
Nov 10, 2014 08:27 PM
1320london
Feb 15, 2014 03:52 PM
A lil 2.3l action
Mid-Atlantic (Sales)
Apr 28, 2012 04:43 PM
doctorash27
Oct 7, 2011 03:29 PM
hybridpatient95
14
Apr 7, 2005 04:47 AM
