Sunroof issues 93 Prelude
Old Sep 21, 2009 | 08:50 AM
ludesrv's Avatar
Default Sunroof issues 93 Prelude
I can't get my sunroof on my 93 Prelude to move at all. I checked the fuse it's good, the switch is good (sends out voltage in both direction) but the motor/sunroof doesn't appear to budge. If there a mechanical override so I can cycle the sunroof, grease it up, and inspect the motor assembly?
How do I inspect the motor, is it easy to remove?
Old Sep 21, 2009 | 11:12 AM
mphsprelude's Avatar
Default Re: Sunroof issues 93 Prelude
the override is the little circle plug thing on the ceiling just behind the brake light in the window. you use a hex i think to turn it. i had to do the same thing. a little grease and it will be good as new.
Old Sep 21, 2009 | 03:29 PM
pkolaboy's Avatar
Does it sound like it's trying to move?
Old Sep 21, 2009 | 08:10 PM
ludesrv's Avatar
Not really? I don't hear the electric motor in stall (electrified but not spinning). I'm afraid the electric motor is dead. I will try to override and grease the track. Hopefully she becomes alive.
Old Sep 22, 2009 | 09:50 PM
ludesrv's Avatar
Well the track is free and I found out why I never got one of the signals (close). Turns out I'm missing a relay. Oh well, easy fix. Problem is, the motor is for sure dead. I tried to run 12 volts directly to it, seeing as it's a ground thru mounting setup, it was easy to do. But nothing came of it. I need to really get this thing going, how hard is it to change that motor?
My honda manual shows its hard as hell.
Old Sep 23, 2009 | 11:11 AM
ludesrv's Avatar
PRoblem solved. Someone with sticky fingers had taken a relay from me. Turned out the relay's are NC as a ground, and when you use the switch you just turn on the signal to transform the ground to a 12V supply thus powering the motor. Super easy fix, junkyard relays did the job, and they were free!
Took some troubleshooting with a honda manual and some good practice with a volt meter.
Old Sep 23, 2009 | 01:25 PM
kingofgtmo's Avatar
New User
Mine froze on my aswell. I just went to the junk yard and picked up a fifth gen glass if your gonna pull the roof apart might aswell do the mod. looks friggin awesome!!!!!
HBK*fresh
Nov 20, 2008 03:42 PM
ProjectTib
Jun 9, 2007 08:37 PM
vtec fan
Jun 19, 2006 06:13 PM
DjN3M3S1S
Jul 25, 2005 03:30 PM
