sunroof wont close "93 civic
alright so it started to rain the other day when it was open. so i started to close it but it didnt close all the day, so i tried pulling it.
now its the even, so i took off the glass, and noticed that the driver side works fine, but the other side stop halfway.
i sprayed some wd40 and tried pushing it back in so it will at least close, but no luck.
i ended up having to close it manually, but the back side it still popped up..
any ideas?
any ideas?
Re: sunroof wont close "93 civic (DjN3M3S1S)
If you keep turning the manual screw I am prety sure the back will close as I am pretty sure that mine did when I had to do it manually once. I have a 93 Hatch and mine is giving me **** too mine will open fine but when it comes time to close it seems that something is wrong with the motor and I have to pull it along. Sounds a little different than your issue but I just plan on replacing the motor at some point.
Imperious: Mod of Valor
Re: sunroof wont close "93 civic (ralphie14)
It's most likely the motor, mine runs a bit slugish too. Espically when I'm the freeway, I guess the wind going against it makes it go slower than normal.
honda25
02-07-2003 06:01 AM
