AEM UEGO on '96 Integra LS
Old Sep 21, 2009 | 08:19 AM
Glehman1's Avatar
Default AEM UEGO on '96 Integra LS
Hey guys,
Quick question for you... Could save me a lot of time/trouble.
I have the AEM Wideband O2 Sensor & afr gauge setup INSTALLED and working. When I installed it, I routed the analog output to my stock ECU. I am getting a CEL code #41 which is either O2 sensor heater malfunction or circuit interruption.
Should the gauge's analog output be working with my stock ECU?
It should be noted that I moved my exhaust manifold O2 sensor to the post Catalytic converter position to replace a broken one. It fit into the harness fine, I don't see why that would be the issue.
Old Sep 21, 2009 | 08:22 AM
mrdeadman's Avatar
They let me pick
Default Re: AEM UEGO on '96 Integra LS
Do you still have an 02 in the header?
Old Sep 21, 2009 | 03:11 PM
Glehman1's Avatar
Yes, I replaced the O2 sensor in the header with the new wideband one.
Old Sep 21, 2009 | 03:40 PM
mrdeadman's Avatar
They let me pick
From AEM:
Q: Do I still need to run my factory exhaust gas sensor if I have an AEM wideband UEGO controller? A: Maybe. If your vehicles Engine Management System uses the O2 sensor for fuel control and you cannot recalibrate it for this different sensor signal, then you will need to retain the factory sensor. If you are running a factory ECU then you will need to continue to send it the factory narrow-band signal or it will throw a Check Engine Light (CEL). Additionally, on emission controlled vehicles in California you MUST retain the unmolested stock emission system for emissions legality.
bpoweredeg6
Apr 14, 2013 08:51 PM
balbowskie
Engine Management and Tuning
Apr 8, 2013 10:00 AM
HyperFlow
Oct 2, 2010 08:55 AM
njebudalla
Feb 22, 2009 01:43 PM
turboHX
Aug 3, 2005 12:38 PM
