Cruising while holding at vtec crossover
Old Sep 21, 2009 | 07:13 AM
alexthegrinch's Avatar
Default Cruising while holding at vtec crossover
Have any1 here ever experience while driving or cruising, at vtec crossover. I have s2 stage 2 with 304 bordermax exhaust. So sometimes i would cruise and hold d fuel at d crossover point. It produces a note- tak tak tak. Kinda cool exhaust note. Any1 here experience it b4? Any bad side effects towards this?
Old Sep 21, 2009 | 07:57 AM
Top Ramen's Avatar
Default Re: Cruising while holding at vtec crossover
If it is tuned properly, it shouldn't make any difference where you hold a constant rpm level.
Old Sep 21, 2009 | 07:59 AM
92TypeR's Avatar
FSAE
Sounds to me like you do not have a fully tuned fuel map.
What are you using to tune with? (ie: Hondata, CROME, etc)
Old Sep 21, 2009 | 09:57 AM
ddd4114's Avatar
Do you have the VTEC engagement and disengagement points set for the same engine speeds?
Old Sep 21, 2009 | 10:07 AM
Top Ramen's Avatar
I was assuming he didn't do that (it would be pretty dumb), but since this is H-T, you are right to ask. ; )
Old Sep 21, 2009 | 05:14 PM
ddd4114's Avatar
Haha, exactly what I was thinking.
Old Sep 21, 2009 | 05:34 PM
00Red_SiR's Avatar
All Motor Mentor
new English? d=the?
Old Sep 21, 2009 | 08:30 PM
1.5Slowmatic's Avatar
doesn't VTEC only engage while at a certain Throttle position anyway. Cant remeber the % off hand though
Old Sep 21, 2009 | 09:09 PM
ddd4114's Avatar
The prerequisite is load, based on manifold pressure.
The actual value depends on the ROM (and can be adjusted). For a p30 base, it's ~400 mbar.
ken2830
Dec 25, 2006 11:08 AM
PM-Performance
Mar 1, 2005 08:45 AM
RemerLex11
Jul 10, 2004 06:31 PM
el arbi
Mar 14, 2003 04:03 PM
