wiring fog lights on a crx????
Old Sep 20, 2009 | 08:49 PM
michael-crxsi's Avatar
Default wiring fog lights on a crx????
ok i just got some fot lights that came with all the wires.
got everything wired up in the front, ran the wire into the firewall and everything now im confused. from the switch there are 3 wires, black is ground, white is to lights, and red is the power. i dont know what to do with the red one. it says to hook up to battery terminal or strait to battery, but the cord the supply is like a foot long so there is no way. ive heard some one say to hook it to the fuse box but to where?
Old Sep 21, 2009 | 04:42 AM
dephtone's Avatar
Default Re: wiring fog lights on a crx????
You can run it to the fuse box, however I would suggest getting a longer wire, just cut and solder an extension onto the wire so you can reach the battery, also make sure you run an inline fuse just so if it does craps out, you won't melt anything.
Old Sep 21, 2009 | 04:59 AM
crx_si-r's Avatar
i would also add a relay if one was not included. but the right way to do it would be to hook it up headlight switch. the OEM fog light harness plugs in right here....
then again im assuming you have oem fogs and harness.
Old Sep 21, 2009 | 07:08 PM
They aren't OEM fogs. They are after market one
Old Sep 21, 2009 | 08:25 PM
crx_si-r's Avatar
yea, i get that you bought the cheapie lights, but what im saying is that if you plug the main power source wire to this location then your fogs will light up the way they are supposed to. i.e. when you turn your headlights on your fog lights will light up as well.
Old Sep 29, 2009 | 05:39 PM
it looks nothing like that
the wire i need to connect to the fuse box or some think looks like a metal c at the end of the wire
like this
----------------C
Old Sep 29, 2009 | 05:57 PM
crx_si-r's Avatar
that is a generic, harness. the way they want you to hook it up is to the battery's positive cable.
Old Sep 30, 2009 | 06:54 AM
The wire is about one foot long so there is no way it is going to reach the battery. I need to know where I can get power from the fuse box
dingobat
May 25, 2009 05:11 PM
immajackuup
Apr 2, 2008 09:07 AM
Shaynepolevault
Lighting
Jan 14, 2008 02:47 PM
Shpoo
Oct 10, 2003 11:52 PM
xsuperdanx
May 11, 2003 04:31 PM
