Help with wiring! 92-95 Civic fog lights - DEPOs
I searched some of the other threads about fog lights but I haven't found the answer. I just bought some for my 93 Civic 4 door and I'm having some trouble with the wiring. On one end of the fog light wiring harness there's a red wire w/ fuse that looks like it connects to the battery. The other end of the harness has a red male connector. Is this the wire that I run into the cabin and connect to the female (red/black) wire on the switch harness? If so, I had it connected that way but every time I tried to turn on the fogs it would blow the fuse in the fuse box. I had the switch harness connected to the #2 jack in the fuse box. I'm I missing something here?
thats how i hooked mine up.....
-red wire with fuse + ring to the battery
-black with ring to ground
-pluged in relay, lights
-red wire into cabin, to switch harness
-switch harness to red wire in cabin and switch
but i dont remember where i plugged the harness into the fusebox. should be the one thats hot with ur parking lights...
which fuse to u keep blowing?
Re: (dantastic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dantastic »</TD></TR><TR><TD CLASS="quote">thats how i hooked mine up.....
which fuse to u keep blowing?</TD></TR></TABLE>
thats how i did mine and i plugged into #2
make sure none of the wires are smashed anywhere
Re: (dantastic)
Thanks for the reply.
I had the switch harness connected to the #2 outlet on the fusebox (red arrow). When I tried to turn on the lights I kept blowing the "Parking lights, Inst. Lights, Lic.Plate Light" fuse (yellow circle). I even tried a different outlet other than the #2 and I blew that fuse also. Maybe I don't have a good ground.
Re: (Timmay)
Damn, I must have a short somewhere. I guess my only option is to open up the harness and trace back each wire.
Thanks guys...
Modified by Shpoo at 11:48 PM 10/8/2003
Thanks guys...
Re: (BeerMan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BeerMan »</TD></TR><TR><TD CLASS="quote">Nice thread, I've had my foglights for 3 months, never installed because I'm wiring ignorant.
Too bad I totalled my hatch last weekend, :sniff: </TD></TR></TABLE>
Sorry about your hatch...
aftermarket fogs come with weaker wire that is more prone to becoming frail and weak. Grounding wires are very important as I learned. If not in contact with an appropriate grounding source the lights will go on and off repeatedly. Good luck with the install.
michael-crxsi
09-30-2009 06:54 AM
philosofy1
04-21-2007 03:48 PM
ShakesTheKlown
03-29-2004 09:19 AM
