ok guys i believe i understand it now let me know
ok so i got a obd2 motor with a obd1 harness i just use the obd1 harness and just get a obd1 dizzy obd1 injectors an obd1 alternator and just get a obdo to obd1 harness conversion and also could get the injector Conversion Clip Set and just will need obd1 ecu is this correct guys let me know
I think you've got it. But you can't write a sentence to save your life, so I'm not sure.
If you have an OBD2 engine, you will need:
1. To use your existing harness and add the plugs/wiring necessary for engine
2. Either an OBD1 or OBD2 distributor with corresponding plugs
3. OBD0->OBD1 conversion harness
4. OBD1 injectors with injector clips
5. OBD1 ECU
5. OBD1 ECU
. . . all I needed was obd0-obd 1 jumper harness, obd1 dist. and obd1 ecu, 4 wire o2 sensor. . but being that your motor is obd2 you will have to use obd1 injectors. .
well you may have an obd1 harness.. but you need the stock obd0 harness.
also, you don't need obd1 injectors. just because his engine was originally obd2 doesn't mean squat. he can run the obd1 ecu and obd0 injectors with the resistor box.
5. OBD1 ECU
5. OBD1 ECU
yes texas rep but so yea i do need a full obdo harness and my obd1 i need to sale are what im trying to do no cutting on my harnessa and yes def convert to obd1 i do got the obdo chassis harness
vtecftw
Aug 11, 2007 11:15 AM
