Apexi VFAC II on K20A2 with H/I/E
Old Sep 20, 2009 | 03:17 PM
Tamo's Avatar
Default Apexi VFAC II on K20A2 with H/I/E
I have a K20A2 with H/I/E. What are the best settings without turning on the CEL?
For optimum fuel/air mixture that produces power. And best High cam switch over points.
Old Sep 21, 2009 | 08:47 AM
mtber's Avatar
Default Re: Apexi VFAC II on K20A2 with H/I/E
1. Remove the afc.
2. Buy hondata k-pro
3. Be happy
Old Sep 21, 2009 | 02:50 PM
Tamo's Avatar
I have it already,it came with the car.
At least I'll use it learn a little.. and get as much HP as I can.
Old Sep 21, 2009 | 02:59 PM
Tamo's Avatar
Actually it's not that bad, it controls A/F ratio, VTEC engagement, and VTC .. which is pretty good when it's free
Old Sep 21, 2009 | 07:22 PM
mtber's Avatar
It doesn't control ignition timing.... (important).
You won't get any results without dyno tuning the car.
Old Sep 22, 2009 | 02:16 AM
Tamo's Avatar
If I had ignition timing, that would make it almost a complete ECU control :D
All I want is few combination or settings, MAP, to get alittle HP out of it. 3WHP is fine. I said, I have it for free, why not use it for the moment.
Serenity Now!
Mar 1, 2007 11:34 AM
Double Agent
Mar 17, 2006 07:43 AM
twobit
Apr 17, 2005 06:15 PM
mrx
Mar 9, 2005 07:13 AM
R3dL1n3
Oct 23, 2002 04:15 AM
