Volt meter gauge installed
Old Aug 27, 2002 | 09:19 PM
EVOCELICA's Avatar
New User
Default Volt meter gauge installed
I just installed my volt meter gauge and when it is turned on it reads way over 18 volts is that correct. I thought a car battery runs 12 volts. I just want to make sure that the gauge is working correctly.
Old Aug 27, 2002 | 10:35 PM
sparkz's Avatar
Default Re: Volt meter gauge installed (EVOCELICA)
with the car running, it should read about 14volts.
Old Aug 27, 2002 | 10:43 PM
EVOCELICA's Avatar
New User
Default Re: Volt meter gauge installed (sparkz)
with it running it reads way over 18 it is like the needel is pegged all the way when the gauge is on.
Old Aug 27, 2002 | 11:31 PM
civicrtype's Avatar
Check the install or maybe a f-ed up gauge. Like said above when the car is on it should measure approximately 14 but should always be btw approx 12-14 depending on what you have on, like a/c, lights, system, etc. If your car was running on 18volts then your alternator is overcharging and can cause you battery to burst. First check install, then test voltage output on alternator, if all is ok then gauge is no good. Good luck. One.
Old Aug 28, 2002 | 12:59 AM
EVOCELICA's Avatar
New User
Default Re: Volt meter gauge installed (civicrtype)
Thanks for the heads up
Old Aug 28, 2002 | 04:53 AM
EE_Chris's Avatar
It sounds like the alternator is being full-fielded or the regulator shorted. Have you checked the wiring from the alternator to the ECU?
Make sure that each wire in the alternator connector has continuity to the corresponding wire at the ECU.
Make sure that each wire is not shorted to ground.
Make sure your grounding points [all of them] are clean and tight.
Check ELD output voltages with various loads turned on: the voltage should decrease as loads are turned on.
Other than this...Its Helms time.
Old Aug 28, 2002 | 08:21 PM
EVOCELICA's Avatar
New User
Default Re: Volt meter gauge installed (EE_Chris)
Well I tried another battery and it reads 9 volts so I am guessing that the gauge is working
ufakeit
Jun 5, 2008 11:26 PM
speedemon
Jan 13, 2005 09:43 PM
hondura
Jul 7, 2004 05:18 AM
redman223
Audio / Security / Video
15
Jun 10, 2003 06:15 PM
sleepy
Jun 19, 2001 08:15 PM
