Transmission & Drivetrain Gearboxes, Differentials, Clutches
b16 trans install problem
Old Sep 20, 2009 | 09:14 AM
90 JDM EF8's Avatar
Default b16 trans install problem
i have a b16 that im putting the trans back in and the trans bolts back up fine but when i bolt it up and check the cable clutch arm for it doesnt move up and it sounds like it hitting something, i never messed with the clutch either, i just pulled the ls trans off and put the b16 one in and the arm moves fine when trans isnt on the car and everything worked fine when trans was on the car before...any one have an idea what could be wrong? thanks for any info
Old Sep 20, 2009 | 01:45 PM
adamrich33's Avatar
Default Re: b16 trans install problem
the clutch fork probaly moved on you and popped out of the clip, you can get it back in w/o removing the trans
AllMotorAri
Aug 14, 2012 10:16 AM
99ekexsi
Mid-Atlantic (Sales)
Mar 10, 2011 02:26 PM
bigtom388
Mar 17, 2010 01:53 AM
90 JDM EF8
12
Sep 25, 2009 08:44 AM
90SiReX
Dec 2, 2008 01:19 PM
