b16 trans install problem
i have a b16 that im putting the trans back in and the trans bolts back up fine but when i bolt it up and check the cable clutch arm for it doesnt move up and it sounds like it hitting something, i never messed with the clutch either, i just pulled the ls trans off and put the b16 one in and the arm moves fine when trans isnt on the car...any one have an idea what could be wrong? thanks for any info
wait my bad didnt read correctly it sounds to be ok because tht sound u haere is probably the sound of the throw out bearing collar kissing the pressure plate teeth this happend to me too it freaked me out lol but it should be fine just hook up the clutch cable and test it with ur foot not ur hand..
Well see sir, if he became a teacher you would be the child that would drop out of school. So he would have then wasted his valuable time trying to teach incompetent fools. He would have had more satisfaction being the General Manager at the McDonalds where you work at. You work there because nobody would give you a job with out even a GED, but he felt sorry for you. He remembered a time when some fool on Honda-Tech could not spell for **** and decided to give an uneducated drop-out a chance.
To the OP did you get that taken care of?
2.) I "neva eva" need to figure out what is wrong with my cars because when there is a problem I already know what it is.
3.) Finally, I "neva eva" need to hop in and learn anything because I don't create threads asking for help. I know a lot but I do not know it all. I help other people out just like I am helping you with your ignorance. You are starting to learn, VERY SLOWLY at that, and I can see you have tried to improve your grammar skills.
OP are you sure that it isn't hitting the "fingers" on the pressure plate? When the transmission is bolted to the motor it will not go up the full swing like it did when it is out of the car. You actually have to pull on it very hard to depress the pressure plate to disengage the clutch.
