Obx turbo
Old Sep 20, 2009 | 08:35 AM
jhhj332007's Avatar
Default Obx turbo
I have had obx parts in past the worked well but have never tried one of ther turbo has anyone ever tried a obx turbo before???
http://cgi.ebay.com/ebaymotors/90-01...Q5fAccessories
Old Sep 20, 2009 | 08:58 AM
jhhj332007's Avatar
Default Re: Obx turbo
bump
Old Sep 20, 2009 | 11:31 AM
jhhj332007's Avatar
noone
Old Sep 20, 2009 | 12:14 PM
jhhj332007's Avatar
any opions about it
Old Sep 20, 2009 | 12:29 PM
street_ride14's Avatar
turbocharger is the heart of an FI system, get something you'de be proud of and know it'll last, do not get OBX.
Old Sep 20, 2009 | 01:15 PM
jhhj332007's Avatar
Jw i was gonna go with garrett...or turbonetics...just wondering everyone opion
Old Sep 20, 2009 | 01:23 PM
bigD's Avatar
search you are not gona get much help on something that has been talked about plenty
Old Sep 20, 2009 | 01:32 PM
jhhj332007's Avatar
I can't find anything tried searching here and on google
Old Sep 20, 2009 | 01:37 PM
king06's Avatar
It's the same Chinese stuff that's all over eBay.
Some people have had luck with those turbo's, but IMO, i would just get a nice $800 turbo and a cast mani from a reputable company or save up and get something nicer.
The inlinepro cast looks nice.
Old Sep 20, 2009 | 01:56 PM
jhhj332007's Avatar
No saving money about it the turbo only range from $600-$1600. on there website....How about the axles they are rated to 1000hp with 5 year warranty??
Old Sep 20, 2009 | 02:07 PM
jhhj332007's Avatar
Thanks for help
Old Sep 20, 2009 | 02:20 PM
jhhj332007's Avatar
Any links for more info
Old Sep 20, 2009 | 02:34 PM
jhhj332007's Avatar
Has anyone ever really had one or just saying ther $h!t cause there not one of the normal brand names???
Old Sep 20, 2009 | 02:54 PM
jhhj332007's Avatar
UP for info if anyone has it or has personal experience
Old Sep 20, 2009 | 03:03 PM
jhhj332007's Avatar
or opions
Old Sep 20, 2009 | 03:33 PM
jhhj332007's Avatar
NOONE
Old Sep 20, 2009 | 03:36 PM
bigD's Avatar
cheap china junk maybe you should get it and let us know how it turns out
Old Sep 20, 2009 | 03:44 PM
96 GSR-T's Avatar
Stop bumping threads that never leave the top for starters....
Its China Junk, no matter how you look at it....
Performace axles with a 5yr warranty?? Pleazzze.....
Old Sep 20, 2009 | 08:18 PM
srmofo's Avatar
I suggest you start here
https://honda-tech.com/forums/forced-induction-16/%2A%2A%2Aforced-induction-forum-faq%2A%2A%2A-1024174/
Ive picked out the important thread for you
https://honda-tech.com/forums/forced-induction-16/noobs-ebay-turbos-your-questions-answered-1749857/
Old Sep 21, 2009 | 06:34 AM
jhhj332007's Avatar
Drag Race Spec. Axle/Hub Kit for Honda B-Series
OBX Drag Race Spec Axles are a definite must for any enthusiast that is putting up SERIOUS horsepower numbers. The CV design on this axle is built to handle 1000+ horsepower.
Our axles are compatible with the standard spline size on the differential end for easy installation and are compatible with OEM or aftermarket drop-in differentials as well as differential spools. Along with the axles are new hubs that fit the stock bearing sizes as well as new extended studs for installation. New ABS rings have already been installed on the axles.
Please note: The hubs are made for 94+ Integra and 92+ Civic with ABS or 99-00 Civic Si knuckles. If you are using these for a Civic that did not have ABS, you must change the knuckles to one of the above due to the wheel bearing size.
1. Designed for 94+ Acura Integra (except Type-R) and 92+ Honda Civic using B-Series hydraulic transmissions
2. CV design capable of handling 1000+ horsepower
3. Compatible with standard spline size for easy installation
4. Works with OEM or aftermarket drop in differentials and spools
5. Backed by 5 year limited warranty against manufacturer defects
Click the "Order" Button to add an item into your shopping cart.
ITEM # DESCRIPTION PRICE QTY.
11423-1 OBX Drag Race Spec. Axle/Hub Kit for 94-01 Acura Integra (except Type-R) $1000.00
11423-2 OBX Drag Race Spec. Axle/Hub Kit for 92-95 Honda Civic $1000.00
11423-3 OBX Drag Race Spec. Axle/Hub Kit for 96-00 Honda Civic $1000.00
Old Sep 21, 2009 | 06:41 AM
jhhj332007's Avatar
Originally Posted by srmofo
I read that in 2004
Old Sep 21, 2009 | 06:48 AM
srmofo's Avatar
Originally Posted by jhhj332007
I read that in 2004
then why are you asking in 2009? ....and considering your join date, it sounds improbably.
Old Sep 21, 2009 | 06:55 AM
jhhj332007's Avatar
I just trying to here a bad experience with them turbos?
Old Sep 21, 2009 | 06:56 AM
dephtone's Avatar
I read that in 2004
Everyone is pretty much going to give you the same answers as they already have. OBX is more or less hit or miss just like anything on eBay.
In the world of FI you get what you pay for. So would you want to pay 900 for a mani and turbo that will crack and start smoking out of the seals after maybe a couple of months and then buy another known good turbo brand for 600 bucks? I know you can check out the Marketplace and get a used good mani and t3/t4 for ~800 if you shop around.
Do it right the first time or don't do it at all, it's just a gamble, if you are second guessing it, more than likely it is not a good idea.
According to that Ebay post it says it's running a 1.01 AR...wow
Old Sep 21, 2009 | 07:30 AM
mdpc20653's Avatar
you get what you pay for.. budget boost = bad. theres a few things you can be cheap on and the turbo is not one of them
