Full B20 in EG Hatch
Old Sep 20, 2009 | 04:35 AM
CivicSIR20's Avatar
Default Full B20 in EG Hatch
Im dropping a full b20 out of a 00 crv in my eg hatch this week and wanted to know if anyone has done this and what steps they took to building this thing without a vtec head. I understand the b20 lacks major power in top end without the head but at the moment its almost impossible to find a good head where im from that hasnt been beat on and will cost me my *****, thanx for your help
Old Oct 5, 2009 | 08:04 AM
CivicSIR20's Avatar
Default Re: Full B20 in EG Hatch
I put the swap in and it runs good. if anyone has any advice as to where i should go from here id be glad to hear it
Old Oct 5, 2009 | 08:24 AM
.Manny.'s Avatar
Touching My Member
how much power do you want to make?
Old Oct 5, 2009 | 08:34 AM
92 EH2's Avatar
honestly, if you want to build it, i would just save up and wait for a good deal on a head. maybe buy a good header, it really depends on your plans, if you want buy a set of pistons, unless you plan on keeping the block stock. either way just save the money and buy the head, because you will not regret it.
Old Oct 5, 2009 | 09:35 AM
Jimster480's Avatar
I believe you cant use the stock B20 tranny anyway. There is no real point in building it without a VTEC head. B20 VTEC makes good power, without a VTEC head you wont be making top end power ever.
Old Oct 5, 2009 | 09:57 AM
roycivic92's Avatar
i have that swap, coming from a sohc the b20 kicked *** for about a week, then i got used to it. i guess my jdm itr tranny keeps me out of the b20 power band. but vtec here i come SOON.
Old Oct 5, 2009 | 09:59 AM
ej1love's Avatar
listen to jimster
Old Oct 5, 2009 | 10:00 AM
v8killaz's Avatar
boost
Old Oct 5, 2009 | 10:02 AM
roycivic92's Avatar
u can allways cam it up , makes good power
Old Oct 7, 2009 | 03:23 AM
CivicSIR20's Avatar
Yea i was thinkin about buying a set of cams but i guess it be just as good to save up and get the head, id like to keep this thing all motor and im considering experimenting with some itb setups, anybody know who makes a nice set of itbs and how much work itll be to tune it?
Old Oct 7, 2009 | 06:36 AM
Jimster480's Avatar
even if you put cams in it it really wont make any good high end power. The head is built to flow for low end power. And high end power without VTEC = useless. B20 VTEC will just be better all around. You will keep the lower end TQ that you get from the longer stroke and you will get high end power from the high end flowing head and VTEC.
Old Oct 7, 2009 | 08:09 AM
darrinbrewer's Avatar
you can go ahead and get a nice header, then once you get the head, it'll bolt right on.
i drove a b20z for about 3 months before doing a vtec head
Old Oct 7, 2009 | 07:52 PM
axegrinder87's Avatar
ive read a few long threads on the obx itbs, word is they're made in the same factory as the todas. all they are are stock toyota itbs on an adapter to fit b series heads, not too hard to screw that up. theyre pretty damn cheap compared to any others, and you can find em on ebay. as far as tuning goes, hondata has a feature which makes tuning with itbs a lil bit easier, but itll still take a good bit of dyno time.
Old Oct 8, 2009 | 04:29 AM
Jimster480's Avatar
toyota ITBS?
Old Oct 8, 2009 | 03:10 PM
Originally Posted by Jimster480
toyota ITBS?
yeah there was a stock corolla in japan that came with itbs. its an early 90s model, dont remember exactly which years though.
Old Oct 8, 2009 | 03:22 PM
Jimster480's Avatar
dam wtf
Old Oct 8, 2009 | 07:30 PM
StockandSlowEG6's Avatar
I believe it was the 80's ae86 20 valve...as did some of the 16 valves
Old Oct 8, 2009 | 07:52 PM
93egSLEEPER's Avatar
if your going to throw a vtec head on a stock b20 block i highly reccomend staying out of high rpms unless you throw a set of arp rod bolts in. b20's were not built stock to turn 8k like all the other dohc vtec motors out there.
Old Oct 8, 2009 | 08:03 PM
Jimster480's Avatar
as long as he keeps it around the stock B20 redline it will be fine.
Old Oct 8, 2009 | 09:26 PM
94_DC's Avatar
Which is 6400 so he will only have VTEC for 1200 rpms which is pointless.
Get the ARP rod bolts done.
Old Oct 8, 2009 | 09:57 PM
fastrxu's Avatar
Rebuild a 16g forget itb's
O shet i started the turbo vs all motor war again
Old Oct 8, 2009 | 10:29 PM
slammed em1's Avatar
get a b20z and run that for a while.....if your gonna build it, just save up and get the vtec head done.....do it right and u wont regret anything...
Old Oct 8, 2009 | 11:51 PM
roycivic92's Avatar
with arp rod bolts in the b20 vtec how high are u guys reving
Old Oct 9, 2009 | 08:09 AM
Jimster480's Avatar
You will also need a GSR or B16 oil pump if you want to take it pretty high. Although I would say with ARP bolts it would probably be safe to like 7500 (with a B series VTEC oil pump aswell)
Old Oct 9, 2009 | 09:10 AM
roycivic92's Avatar
7500 that it?
