Help B18 problems
Old Sep 20, 2009 | 01:16 AM
Sidewayz_240's Avatar
Default Help B18 problems
I have an ls in my ef, that has been acting up. For a while the rpms would jump all around, I am led to believe that this is the symptom of a bad ICM. But today when I was driving, I stopped and my car shut off. I started it again and it cranked right up, but every time I press the gas to go, the car just shuts off again.
Would the ICM cause my car to shut off when I hit the gas, or is it something else? I need help quick please, as my car is sitting on the side of the road until I can trailer it back to the house, hopefully I can fix the problem on the sport and drive her home.
Old Sep 20, 2009 | 08:55 AM
dephtone's Avatar
Default Re: Help B18 problems
Sounds like you do have a bad Ignition Control module, jumping tach needle is always a pretty sure sign of this.
You should check the CEL codes also, because the ICM will def throw code 15. Check to make sure you don't have any other issues while you are at it. Just trailer the car home and work on it there as you can look up online if you happen to find some other code stored in the ECU.
Old Sep 20, 2009 | 11:00 PM
Ok im going to replace that, how about the main relay can that cause this problem as well.
Old Sep 23, 2009 | 10:21 AM
Ok, so Im going to replacen the ICM, but would this cause my car to shut off when I hit the gas? I need to get this thing back on the road!
Old Sep 23, 2009 | 10:44 AM
dephtone's Avatar
You need to check the codes and figure out what codes the car is throwing first. This will tell you what is wrong for the most part.
The tach needle jumping around is either the Igniter going out in the distributor or you have a small short in the blue tach wire, but more than likely it's the first of the two.
Old Sep 23, 2009 | 10:52 AM
My engine check light doesnt even turn on, like at all. How do I check codes on obd0, look at the light on the ecu?
Old Sep 23, 2009 | 11:53 AM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
Yes.
Old Oct 30, 2009 | 01:43 AM
Still stumped!
Old Oct 30, 2009 | 07:47 AM
DO IT ON ALL FOURS
Have you actually changed anything yet, or what?
Old Oct 30, 2009 | 10:12 PM
Tried a different main relay from a running car, and it still shuts off when i hit the gas. Could it be the TPS?
Old Oct 31, 2009 | 07:29 AM
DO IT ON ALL FOURS
Could be a bad TPS, but it also sounds like the MAP Sensor could be bad.
Old Nov 1, 2009 | 06:48 AM
Thanks im going to hit the yard for those parts!
patrickstar
Oct 29, 2011 06:18 PM
Eclectia
Sep 12, 2010 11:11 AM
highneo
May 25, 2006 09:06 AM
BlackEJ6
Jan 13, 2006 03:02 PM
99CivicExCoupe
Nov 19, 2004 10:25 PM
