IAC/ FITV gone?
Old Sep 19, 2009 | 06:33 PM
WeB's Avatar
WeB
Default IAC/ FITV gone?
So.... I have the famous bouncing idle problem, did some research on HT and found how to clean the IAC and FITV. Did IAC first because I already knew how to do it ( helped a friend clean his a while back). Then I went to clean my FITV....only its not there. The three 10mm bolt holes are there but there is nothing there. Now I'm not 100% positive that my car has one, but I thought older (OBD1/OBD0) would have them for sure. Engine is a DOHC ZC with stock intake manifold for it. Would not having this make the idle problem continue to happen?
Old Sep 19, 2009 | 09:24 PM
mother ef-er's Avatar
Default Re: IAC/ FITV gone?
.. dude got jacked!
Old Sep 20, 2009 | 03:01 PM
WeB's Avatar
WeB
^apparently... So I cleaned out the IAC and it was working fine for a bit now it's back to doing the same roaming idle but significantly smaller jumps, was 250-1700 RPM before, now its only 1000-1400. Guess I'll try cleanining it more thoroughly... Still confused about the FITV tho
Old Nov 19, 2011 | 11:32 AM
diverpaulo's Avatar
take a look here
this was!!! I found the solution here!!!!!!
http://ecomodder.com/forum/showthrea...ained-967.html
Old Nov 19, 2011 | 06:05 PM
bk7794's Avatar
Hows the throttle cable look? I was a victim and so were a few other people on this forum that had a throttle cable issue binding.
Old Nov 20, 2011 | 01:45 AM
jlicrx's Avatar
the OBD0 DOHC ZC throttle body does not have a FITV - stock throttle body should look like this:
SoB NiG
Jan 21, 2010 07:23 PM
89LSED
10
Nov 20, 2009 11:17 AM
Highlifer
Aug 4, 2007 08:12 PM
gsr1289
Feb 7, 2007 09:17 PM
Shmolie
Jun 29, 2005 05:58 PM
