A/C system - compressor wont turn off...?
Old Sep 19, 2009 | 01:52 PM
hondaZvic's Avatar
Default A/C system - compressor wont turn off...?
finished doing a wire tuck, got everything going and the AC working. only problem is when the car is on, so is the air compressor. even with the switch turned off.
assuming all the wires are in the proper places, any ideas on what i should check?
Old Sep 19, 2009 | 03:07 PM
fcm's Avatar
fcm
Old Fart
Default Re: A/C system - compressor wont turn off...?
If compressor clutch stays engaged there is a "short", find an pull the A/C compressor clutch relay does compressor clutch disengage?
If yes, problem is before relay, relay control lead shorted to ground or ECU/ECM/PCM has a problem.
If no, problem is after relay, lead between relay and clutch is shorted to 12V+.
Question...
Does clutch disengauge when ign. is trned off?
MM&Y of car please. 94
Old Sep 19, 2009 | 03:16 PM
hondaZvic's Avatar
thanks for the quick reply!!!
when i pull the relay, the compressor clutch does disengage/turns off.
when ignition is off, the compressor is off.
99 civic ex.
Old Sep 19, 2009 | 05:33 PM
hondaZvic's Avatar
i went through the engine bay harness and double checked grounds and connections.. no luck.
Old Sep 21, 2009 | 06:03 AM
fcm's Avatar
fcm
Old Fart
Problem is before relay, [or relay itself is bad] the PCM supplies the compressor clutch relay, [coil] with a ground to turn it on, swap out relay to eliminate it as the problem. 94
Old Sep 22, 2009 | 04:33 PM
hondaZvic's Avatar
ok, tried a new relay and nope.
next?
Old Sep 22, 2009 | 05:18 PM
fcm's Avatar
fcm
Old Fart
next?
That means either the PCM/ECM is bad, [constant ground output to compressor clutch relay] or the lead running from the PCM/ECM is shorted to ground, pull relay and find which relay terminal is the PCM/ECM control lead, there will be two power leads, one of the thicker pins, [hot at all times] and one of the thinner pins, [hot in run only] the other thinner terminal is the PCM/ECM control, it should have a ground only when A/C switch is on, if it is grounded, depin the control lead from the PCM/ECM and test it again, if compressor turns off, PCM/ECM is bad, if not find the short to ground of the control lead someplace between PCM/ECM and compressor clutch relay.
Sorry I do not have a wire guide for a 99, on the 96-98 it is a black/red lead, there is only one black/red lead at the PCM/ECM. 94
Old Sep 22, 2009 | 06:04 PM
hondaZvic's Avatar
thanks so much for ur help, ill get on it.
DieMaster
19
May 26, 2024 05:10 PM
gootch
Honda Civic (2001 - 2005)
Mar 15, 2014 04:03 AM
lhd dc2
Aug 30, 2010 06:09 AM
pyromaster114
Aug 13, 2010 01:26 AM
turbob16ef
Jan 11, 2006 03:47 PM
