pros and cons between oil fitting and sandwich
Old Sep 19, 2009 | 11:13 AM
1988_96hb's Avatar
Icon2 pros and cons between oil fitting and sandwich
so im slowly piecing my first turbo kit. Id like to run a fittitng instead of a sandwich so i can retain my oem oil cooler. What are the pros and cons between the two? EDIT: to be more specific for my applications it will go on a stock b18c1 then a b18c1 with a b16 head
Old Sep 19, 2009 | 11:35 AM
1988_96hb's Avatar
Default Re: pros and cons between oil fitting and sandwich
phone wouldnt let me edit my post. To be a little more specific on my setup this will be for a b18c1 and then a b18c1 with a b16 head. Prob with a greddy 18g or gt2860rs turbo. And whichever setup will have a oil pressure gauge. I think thats everything related to my question. Tia
Old Sep 19, 2009 | 03:37 PM
trickeng's Avatar
The Golden Eagle sandwich provides filtered oil to your turbo. The cheap ones do not. This is key for turbo life.
Fittings provide unfiltered oil and can break off over time.
Old Sep 19, 2009 | 06:35 PM
1988_96hb's Avatar
how does it break off? Is there a lot of movement in the line or something? And i think i could find an inline filter for it
Old Sep 19, 2009 | 07:44 PM
Bailhatch's Avatar
Just get a sandwich style one and be done with it.
Old Sep 19, 2009 | 10:46 PM
1988_96hb's Avatar
Id like to keep my oem oil cooler so im looking for an alternative. If i ran my oil cooler and then an oil filter relocator kit i could tap the filtered line going from the filter to the motor for a feed line for the turbo right?
Old Sep 19, 2009 | 11:29 PM
fortillian's Avatar
Sounds good, take pictures and do a write up. Ill be doing this soon.
Old Sep 20, 2009 | 03:56 AM
kyden's Avatar
as far as i know the golden eagle adapter still fits with the oem oil cooler.
Old Sep 20, 2009 | 05:12 AM
redzcstandardhatch's Avatar
something different
yeah, you can stack up things if you want.
that OEM thing isnt really much of a cooler either.
Old Sep 20, 2009 | 05:56 AM
91jdmhatchback's Avatar
I would hate to think honda did it for no reason? but i would like to see how effective it is at cooling.
Old Sep 20, 2009 | 06:43 AM
Bailhatch's Avatar
Just put the oil plate on the factory cooler and run your feed line. There's no need to complicate this.
GT500FTW
Feb 13, 2013 10:40 AM
tremor86
Jan 13, 2005 10:26 AM
15psi of fun
Feb 4, 2003 10:17 PM
rice4life
May 9, 2002 06:57 AM
Spade
Mar 15, 2002 06:36 AM
