how do you transfer s300 datalog from one ecu to another
Old Sep 19, 2009 | 11:02 AM
vy3tnamezz's Avatar
Default how do you transfer s300 datalog from one ecu to another
my old ecu was bad so i got a new one for my s300. how to i transfer all my old datalog over the my new ecu.???
Old Sep 19, 2009 | 11:30 AM
locash's Avatar
Default Re: how do you transfer s300 datalog from one ecu to another
The datalogs are stored in the S300 unit, not the ecu.
Old Sep 19, 2009 | 11:59 AM
GhostAccord's Avatar
Datalogs are no good for programming your new ECU. You need the ROM/.bin file that was created for your original set-up. You should be able to retreive it from the old ECU. Or if you no longer have your old ECU. It should have been saved somewhere on the tuners computer. You need to find whoever it was that originaly tuned your car and see if they have the saved ROM/.bin file for your engine. Then you can add that to the EPROM on your new ECU.
Or maybe Hondata is completely different, I've never used it.
Old Sep 19, 2009 | 12:59 PM
HRTuning's Avatar
Yup, it is.
Old Sep 19, 2009 | 01:21 PM
So Hondata tuners have no ROM/.bin/saved files? Once an ECU is tuned that's it you can't retrieve ROM files from the ECU? Wow I'm glad I never had any interest in switching to Hondata then.
Old Sep 19, 2009 | 02:41 PM
HRTuning's Avatar
You can download the tune in the s300 (Which is still in the s300, so there's no reason to do so when putting the s300 into a different ECU) or have it saved as a calibration on your laptop. Neither of which have anything to do with ROMs, .bins, E/EPROM, or the question the OP posted, which was about s300 datalogs.
Old Sep 20, 2009 | 10:15 AM
vy3tnamezz's Avatar
so when i put my s300 into my next ecu, all my calibration, maps, whatever should be the same???? im kinda confused, not familiar with this
Old Sep 20, 2009 | 10:43 AM
HRTuning's Avatar
Yes, it's all in the s300, which is the whole reason you have it. Nothing changes by taking it out of one ECU and putting it into another ECU that's equivalent.
trick_db
Apr 30, 2006 09:10 AM
ahobbs
Apr 27, 2006 02:59 PM
azn_accord06
Oct 24, 2004 08:00 PM
straightline
Nov 13, 2002 06:52 AM
