Transmission & Drivetrain Gearboxes, Differentials, Clutches
Positraction
Old Sep 19, 2009 | 08:58 AM
JWhip1's Avatar
Default Positraction
How do i take out the posi on my 92 civic it came with the car and i have no use for it. It is a b16a cable tranny and my daily driver so no use for it.
Old Sep 19, 2009 | 06:08 PM
Aquafina's Avatar
Default Re: Positraction
Just leave it in, its not hurting anything.
Old Sep 19, 2009 | 06:17 PM
JWhip1's Avatar
my car clicks when it turns so its causing me to get a new tranny
Old Sep 19, 2009 | 06:24 PM
Mista Bone's Avatar
D Tranny Guru
use proper fluid........it's not hurting anything.
Old Sep 19, 2009 | 06:43 PM
Aquafina's Avatar
Probably the axles. The OEM B16A LSD's use their own internal fluid.
Old Sep 19, 2009 | 10:12 PM
JWhip1's Avatar
i was told that it was the tranny cuz the axles were just replaced
Old Sep 19, 2009 | 10:17 PM
Aquafina's Avatar
Does it click when you turn? If it does it axles. When the OEM viscous diffs fail, they simply act like a stock open diff.
Old Sep 19, 2009 | 10:22 PM
JWhip1's Avatar
yeah it does but he axles are brand new
Old Sep 19, 2009 | 10:28 PM
Mista Bone's Avatar
D Tranny Guru
Chris, you are assuming is has a OEM viscous LSD.....what if it is a clutch setup????
Seems the OP hasn't a clue exactly what he has.
Old Sep 20, 2009 | 12:46 AM
Aquafina's Avatar
Yeah, my assumption is based on the fast that he called it posi. Whenever I hear that thrown around with Honda's, its in reference to an OEM LSD.
Old Sep 20, 2009 | 09:05 AM
JWhip1's Avatar
no its an aftermarket posi that was put on and i have a brand new stage 2 clutch and this is on a cable tranny if that helps
Old Sep 20, 2009 | 01:18 PM
Mista Bone's Avatar
D Tranny Guru
:doublefacepalm:
Old Sep 20, 2009 | 07:52 PM
Aquafina's Avatar
So if you want to get rid of it...
Pull trans
Take apart
Remove LSD
Install OEM diff
Put trans together
Put back in car
Old Sep 20, 2009 | 09:06 PM
JWhip1's Avatar
yeah thats an option or how much do you think i could sell whole tranny for with posi still in?
Old Sep 20, 2009 | 09:56 PM
Aquafina's Avatar
Without know what kind of LSD it is or what shape its in, I can't tell you.
FutureCivic
Jan 14, 2007 04:31 AM
WJHMH
Mar 29, 2006 05:01 PM
LD_EGSICK
Sep 20, 2003 08:11 PM
jaydm98
Sep 7, 2003 07:45 AM
