electircal issues
Old Sep 18, 2009 | 10:56 PM
sohctodohc's Avatar
Default electircal issues
so i was testing my ect sensor today and in my haynes it said if i remember correctly that it should be seeing 5volts.
when i tested it i was seeing 12volts to the sensor, this is positive lead to power wire negative lead to body ground.
im no electrician can someone please explain to me what this means? i also tested it at the ecu pins and i was also getting 12volts?
i know this is kind of a broad question but im pretty well stupid when it comes to wiring and what not.
by the way the reason i was testing sensors is because my car will run and drive fine for awhile but after coming to a stop and shutting the car off for say 5mins, and then turning it back on it will basically cut out and miss and wont barely idle till i let it cool off.
but the heat gauge is showing perfect engine temp so something isnt right,
thanks
KiwiRuss
Honda CR-V & Element
Apr 1, 2022 12:43 PM
HamiltonRex
Oct 6, 2004 01:32 PM
mattssi
Jan 21, 2004 12:15 AM
dumbchild
May 29, 2002 07:06 AM
erniecars
May 20, 2002 12:52 PM
