Integra DC2 Window Switches Removal Help
Old Sep 18, 2009 | 07:58 PM
JTN416's Avatar
Default Integra DC2 Window Switches Removal Help
Hey, I'm looking to replace my DC2 Window Switches with the JDM Faux CF Window Switches. I was wondering, how would I go about in removing the window switches? I searched and couldn't find a DIY on this. I was wondering, do I need to remove my door panels or can I pry the window switches off?
Thanks!
Old Sep 18, 2009 | 09:34 PM
98lscoupe's Avatar
Default Re: Integra DC2 Window Switches Removal Help
you take off the door panel by taking out the screw behind the door handle, then the screw in the coin holder and the panel comes off, and I believe the switch has a screw to remove and then you lift and slide the front of the switch out. It is very easy and quick to do
Old Sep 19, 2009 | 02:34 AM
BlueIntegraBoy's Avatar
To let you know, if you just swap the window switches without doing modifications, your AUTO will work for the passenger side only (and lock out for driver side). In order for everything to work like normal, you would need to dremel some stuff from the CF switch plate and redrill a hole in the master switch to mount the plate onto the switch.
Wheely
Dec 6, 2017 10:48 AM
hondagal2004
Nov 27, 2013 07:55 PM
ay_billy
Jan 25, 2011 02:34 PM
ramoneguru
May 25, 2006 07:39 PM
david90
Jun 7, 2004 03:25 PM
