2300 rpm Idle... Vaccum leak, best way to find it?
Old Sep 18, 2009 | 03:54 PM
akdrag's Avatar
Default 2300 rpm Idle... Vaccum leak, best way to find it?
Hi
I have a d16y8 with a greddy 15g kit... dsm side mount intercooler, 345cc h22 injectors... I just got the car tuned last night and had to end the tuning early because of a massive vaccum leak that we couldn't locate. THe car idles at about 3000 rpm when I start it and after about a minute changes to 2200rpm idle....
So I used brake cleaner and sprayed all my hoses and around the intake manifold... checked all my charge piping... even used soapy water to see if it would bubble. One suggestion was that the intake manifold gasket blew out under boost... is this possible???
So what is the best way to find this vaccum leak? Thanks a ton!
Old Sep 18, 2009 | 03:59 PM
philafelman's Avatar
Default Re: 2300 rpm Idle... Vaccum leak, best way to find it?
carb cleaner around all vacuum lines/intake manifold, etc.....watch for a change in idle. i wouldnt think soapy water would work since the air leak would be sucked in, not pushed out like with positive pressure.
Old Sep 18, 2009 | 04:07 PM
akdrag's Avatar
isn't carb cleaner corrosive to get on wires and hoses? And ya I guess soapy water isn't the best idea... im trying everything I guess
Old Sep 18, 2009 | 04:18 PM
i dont know anything about it being corrosive....but i have used it to diagnose all vacuum leaks ive come across.
Old Sep 18, 2009 | 04:21 PM
akdrag's Avatar
another question, it was suggested that my intake manifold gasket could have blown out from boost..... I just replaced the intake manifold gasket with a brand new one... is this likely the case? Where is the most likely place to get a vaccum leak... keeping in mind I was fine for 2 hours on a dynapack then suddenly got this leak
Old Sep 18, 2009 | 05:00 PM
akdrag's Avatar
bump
Old Sep 18, 2009 | 05:26 PM
akdrag's Avatar
bump
Old Sep 18, 2009 | 05:27 PM
if ur intake gasket is drawing in air....check with carb spray.......maybe retorque the bolts.
Old Sep 18, 2009 | 06:09 PM
boostedcivicsir's Avatar
Mr. Badwrench
if you are scared of carb cleaner, dont be. use 2+2. spray and listen for the rmp change.
Old Sep 18, 2009 | 07:55 PM
Maddman7887's Avatar
Easy Fix.....Spray a can of Brake Cleaner works good and listen for the engine to die down......also as boostedcivicsir said
Old Sep 19, 2009 | 07:40 AM
akdrag's Avatar
Ya I have been using brake cleaner and I re torqued all my bolts and charge piping... Still can't find any vaccum leaks... is there anything else that could cause an idle this high?
Old Sep 19, 2009 | 07:48 AM
akdrag's Avatar
can anyone answer if it's possible that my new intake manifold gasket "blew out" under 8psi of boost... like suggested
Old Sep 19, 2009 | 08:01 AM
are you certain ur dealing with a vacuum leak? do you have a gauge hooked up, and what does it read at idle?
Old Sep 19, 2009 | 08:10 AM
akdrag's Avatar
I do not have a gauge and Im not sure at all I have a vaccum leak... I was getting the car tuned and the tuner was like "**** something just popped off" (because the idle went up to about 2300rpms) then we searched for something and couldn't find the leak... So Im not sure i have a leak but the tuner said he thought it was a leak.... what else could it be?
Old Sep 19, 2009 | 09:13 AM
akdrag's Avatar
bump
Old Sep 19, 2009 | 03:29 PM
maybe IACV problem....check coolant level too. if you can hook up a vac. gauge, that would be a good idea.
afnan
Apr 30, 2014 09:48 AM
HIallday
Sep 13, 2011 10:34 PM
93SiPrelude
Feb 24, 2008 10:39 PM
Silent_Destruct
May 24, 2006 02:10 PM
suprmods
Jan 4, 2006 12:10 PM
