What obd1 distributor fits b16a2?
Old Sep 18, 2009 | 03:12 PM
lunalink's Avatar
Default What obd1 distributor fits b16a2?
im having troubles trying to find a dizzy that'll fit my b16a2 ( swapping in CRX) I've been told that my d16z6(vtec) dizzy will work on it..but does it? if so how? or what other dizzy would work? i would really appreciate any info you guys throw my way.( pics would be so awesome! lol.)
set-up:
88 honda CRX DX
converted obd1
swapped out d16z6 and swapped in b16a2
thanx guys.
Old Sep 18, 2009 | 03:21 PM
ef2 pimp's Avatar
Default Re: What obd1 distributor fits b16a2?
http://cgi.ebay.com/ebaymotors/BRAND...Q5fAccessories
Old Sep 18, 2009 | 03:32 PM
lunalink's Avatar
thats an obd2 distributor im looking for an obd1 dizzy..
Old Sep 18, 2009 | 03:49 PM
DCRB's Avatar
94-95 del sol vtec
Old Sep 18, 2009 | 06:02 PM
lunalink's Avatar
thats a z6
Old Sep 18, 2009 | 06:32 PM
awdgsx96's Avatar
Originally Posted by lunalink
thats a z6
That's the Si you're thinking of. The Del Sol VTEC came with B16A3 and B16A2.
Old Sep 18, 2009 | 09:15 PM
lunalink's Avatar
oh..the cheapest one i've seen is about $260 and thats tooo expensive for a dizzy IMO..
any way to modify the z6 dizzy for it to work?
Old Sep 18, 2009 | 09:40 PM
JCRXTURBO20916's Avatar
quit being cheap and buy the right one, even if you did find a way to make the z6 to fit, it still wont run right, you will never get the timming on point. if you know any one that has a broken b16 dizzy you can switch internals.
Old Sep 18, 2009 | 09:54 PM
lunalink's Avatar
^ so i can swap out the internals? i have the obd2 dizzy it came with.
Old Sep 18, 2009 | 10:18 PM
dcvt16's Avatar
you can use the obd2. its basicly the same as obd1, the plug is different. if you search on here you can find the wiring diagram for both plugs then make a jumper or repin what you have already.
i've used this set up before.
Old Sep 18, 2009 | 11:31 PM
lunalink's Avatar
^ oh that sounds really good..i'll search for that diagram and ill depin and split them into 2 ( as obd1) and repin once its done thanx..
Old Sep 19, 2009 | 04:16 AM
dcvt16's Avatar
for sure.
jrsc90DX
Apr 2, 2011 08:34 AM
RACEPAK
Sep 27, 2005 02:39 PM
ICeDoUt
May 20, 2005 01:27 PM
mattssi
Nov 12, 2003 09:19 AM
blackteg
Apr 15, 2003 04:28 PM
