this is a eazy ?
Old Sep 18, 2009 | 02:41 PM
oldschoollove's Avatar
Default this is a eazy ?
ok i got most of my parts for my obd1 swap all i need is my ECU jumper ...so here the thing can i install the obd1 dizzy and my vtec head and obd1 INJECTOR and run my stock ecu tell i get my jumper cause jhp is outof stock of jumper ?
Old Sep 18, 2009 | 02:47 PM
sanimalp's Avatar
$cat /dev/urandom
Default Re: this is a eazy ?
no.
furthermore, why would you want to use obd1 injectors on your swap when you can use obd0 injectors with no wiring whatsoever?
Old Sep 18, 2009 | 02:50 PM
ok thats all i need to know lol got to find a jumper today then lol
Old Sep 18, 2009 | 07:00 PM
BLU CIVIC's Avatar
Track Advocate
Originally Posted by sanimalp
no.
i'm using obd2 injectors, just had to take out my resistor box
Old Sep 18, 2009 | 07:05 PM
nihad's Avatar
I would never remove a resistor box... All the larger injectors are low impedence
Old Sep 18, 2009 | 07:10 PM
sh!ft's Avatar
Who the fack changed my title?!
no.
who said you had to run a resistor box?
Old Sep 18, 2009 | 11:09 PM
sanimalp's Avatar
$cat /dev/urandom
take it out, cut off the plug, and solder all the **** together.. you left out a few steps there, which is precisely why i say it isn't worth it when obd0 injectors are plug and play, no soldering necessary.
your question makes no sense. No one said you have to, but It makes a lot more sense if you just leave the stock wiring alone. for obd1 and 2, you can't use the resistor box, which is my point. Why waste time removing the resistor box when you already have injectors that work just fine with it still in.
Old Sep 19, 2009 | 06:35 AM
BLU CIVIC's Avatar
Track Advocate
plug is still there and just spliced the injectors...
Old Sep 19, 2009 | 06:45 AM
D16SiHatch's Avatar
actually you've got that backwards. all the larger and largest injectors are high impedance
Old Sep 19, 2009 | 07:30 AM
ok so then with my obd1 swap i should just keep my obd0 injectors and not wire in the obd1 injectors
Old Sep 20, 2009 | 12:37 AM
sanimalp's Avatar
$cat /dev/urandom
That would be my suggestion. It is easier, and requires no wiring change. You can do it however you want though.
you will have enough wiring to deal with for vtec and the 4 wire o2, and those things are necessary wiring modifications.
you can always wire up the obd1 style injectors later.
Old Sep 20, 2009 | 08:07 AM
4drEF's Avatar
Keyboard Humorist
Actually they are low impedance.
If you look at high horsepower applications they go with the resistor box.
There is a limit where high impedance injectors don't perform as well.
Old Sep 20, 2009 | 08:19 AM
crx_si-r's Avatar
dont do something that you are not comfortable with. if you are unsure of going with obd1 injectors and removing the resistor box, then just keep it the way it is with obd0 injectors and resistor box. i kept mine in my lsv and no problems for the last 5 years.
Old Sep 20, 2009 | 11:40 AM
D16SiHatch's Avatar
haha your right, i got that bass ackwards. for some reason i was thinking it was the other way round. saturated injectors do have a slower response time and thusly do not perform as well when they are made to output higher cc's/lb's/hr.
Old Sep 20, 2009 | 11:46 AM
apekd's Avatar
I dont like OBD0 injectors just cause the resistor box makes the bay look cluttered. If your not trying to make a lot of power and want a cleaner bay without extending the injector wires, then get OBD1 injectors.
Thats just my $.02 worth.
Old Sep 20, 2009 | 12:43 PM
well my resistor box is under my dash lol
Old Feb 4, 2010 | 12:19 PM
Htounndea's Avatar
how do u wire in obd1 Injector is it that u run one side right to the ecu and the other u just solder all together do they need to be grounded ?
Old Feb 4, 2010 | 12:31 PM
4drEF's Avatar
Keyboard Humorist
One wire goes to the ECU.
That is the ground wire.
The other wire goes to switched power from the main relay.
Old Feb 4, 2010 | 12:40 PM
Htounndea's Avatar
so one wire goes to like injector1 then the other wire runs to the Main Relay/Ground at the ecu right
surkitroller
Dec 29, 2009 12:58 PM
atarigamer01
13
May 20, 2008 09:23 AM
nevin
Aug 16, 2005 03:21 PM
rogue3221
Nov 23, 2004 11:36 AM
CimorelliCRX
May 16, 2003 09:01 PM
