obd1 b16 idles high
Old Sep 18, 2009 | 02:37 PM
88 EF Hatch's Avatar
Default obd1 b16 idles high
ok so im running an obd1 b16 in my 88 dx hatch. i have no vacuum leaks and i double checked timing and its fine. dizzy is sett in the middle. im running an s300, so when my idle was set on normal, it would idle up and then back down between 1k to 2k. after lowering it down to close my IACV, it idles steady now but at 1500K.. My idle screw is closed all the way and when i open it i idle higher. the only thing that lowers my idle is when i turn the dizzy all the way towards front of car which still leaves my car idling like at 1100. what else can it be? what else can i do?
Old Sep 19, 2009 | 08:06 AM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
Default Re: obd1 b16 idles high
Obviously your tune is WRONG...
sleepers91hb
10
Apr 5, 2012 10:30 PM
ludesrv
Feb 19, 2010 07:41 PM
88 EF Hatch
Sep 18, 2009 05:26 PM
es.roadster
Jan 24, 2009 11:19 PM
95civicB16
Sep 22, 2007 12:21 PM
