Transmission & Drivetrain Gearboxes, Differentials, Clutches
Rebuildin transmission
Old Sep 18, 2009 | 12:51 PM
1BADEGDC2's Avatar
Default Rebuildin transmission
I have a b16 transmission that replaced 2nd and 5th gears from the countershaft and mainshaft with gsr gears. Now that i am going back and putting it all together, the 1st gear on the countershaft hits the differentials bolts. i never removed the diff. What do i do?
Old Sep 18, 2009 | 12:54 PM
1BADEGDC2's Avatar
Default Re: Rebuildin transmission
i would change out this shim with larger one right ...
Old Sep 18, 2009 | 11:03 PM
Aquafina's Avatar
Tap the diff all the way in. The countershaft will not rest on the CSB once the trans is assembled.
Old Sep 19, 2009 | 06:27 PM
Mista Bone's Avatar
D Tranny Guru
Kaaz or Cusco LSD?
Old Sep 20, 2009 | 03:31 PM
1BADEGDC2's Avatar
kaaz ... ill try tappin it in more...
Old Sep 20, 2009 | 03:34 PM
1BADEGDC2's Avatar
it doesnt go any further down ....
Old Sep 20, 2009 | 07:51 PM
Aquafina's Avatar
Have you assembled the trans yet to see if it hits with the countershaft snap ring installed correctly?
Old Sep 23, 2009 | 04:01 PM
1BADEGDC2's Avatar
ok i put it together and now it doesnt hit, but when i put the 72mm shim on the mainshaft it wont turn, and without it, it will turn. How can i figure out what size shim i need?
Old Sep 23, 2009 | 04:32 PM
Aquafina's Avatar
Follow the process in the Helms manual, you'll need a mainshaft base and holder, dial indicator, and a base set the indicator stand on.
efhatch.gsr
Jan 27, 2012 12:51 PM
bigJOE671
12
Sep 27, 2011 09:04 PM
Leland
Dec 13, 2009 08:32 PM
