steering problems
Old Sep 18, 2009 | 11:18 AM
project91crxsi's Avatar
Default steering problems
what is this squeeking noise? and also what is the popping noise that you hear, squeeking noise sounds like its coming from right behind the steering wheel and the popping is from under the car
http://s98.photobucket.com/albums/l2...8091446-01.flv
Old Sep 18, 2009 | 12:14 PM
Default Re: steering problems
bump... anyone?
Old Sep 18, 2009 | 01:50 PM
sohcrx91331's Avatar
the bump noise you hear might be your rack and pinion.i had the same thing going on on my crx and had my rack rebuilt.the bump went away and steering feel improved.as for the squeek,i can't think of anythimg off the top of my head.
Old Sep 18, 2009 | 03:22 PM
i fixed the squeaking noise for now. i looked behind the wheel threw the crack and there was a little pin thing rubbing against the back of the steering wheel and i pushed it back with my key and it sparked and the horn beeped, now when i turn it it doesn't squeak lol
Old Sep 18, 2009 | 08:00 PM
bagpipe goatee's Avatar
That finger rides on the wheel for the horn. Without it, the horn won't work. Originally, there's a fair amount of grease between it and the wheel, but not everyone reapplies it when switching wheels. You should grease it and bend the finger back, or else you won't have a horn.
The other noise you hear could be anything from inner tie rod ends to a bad steering rack to a worn u-joint between the column and the steering rack (or loose pinch bolts), etc.
dth0ng69
May 3, 2016 09:54 AM
VSM EXtasy
Jun 9, 2006 06:07 AM
B16Civic93
Dec 21, 2004 08:23 AM
ice11honda
Sep 2, 2004 12:45 PM
nightrider
Apr 6, 2003 01:10 PM
