EF9 Swap Question
DA's use cabe trans just like the EF does.
You need EF to B series mounts, DA ones will not work here.
Shift linkage, you can either shorten the DA linkage or purchase one for a EF with a B series.
ECU, if staying obd0 run a pr4 out of the integra.
Swap to MPFI if the car is a DX or STD
Check out the FAQ's up at the top, there is a huge article about everything you need.
