OBD1 injector clips required for obd1 ecu?
Old Sep 17, 2009 | 05:36 PM
Future50's Avatar
Default OBD1 injector clips required for obd1 ecu?
If I'm going from an OBD2 ecu to OBD1, am I required to change my injector plugs as well?
Old Sep 17, 2009 | 06:58 PM
93turbo16's Avatar
Default Re: OBD1 injector clips required for obd1 ecu?
The only reason you would need to change your injector plugs is if you change to a OBD1 style injector. Say like a set of RC 440 or DSM 450cc injectors would require you to change to injector plugs.
Old Sep 17, 2009 | 07:48 PM
mtber's Avatar
The ecu does not care if your running obd1 injectors or obd2 injectors (as long as they are both the same size).
Old Sep 17, 2009 | 08:07 PM
Future50's Avatar
At the risk of sounding stupid, what's the advantage to running an OBD1 style injector? Isn't a 440 a 440? Couldn't I get an OBD2 style 440 injector? This was all allot less complicated on my STI lol.
Old Sep 17, 2009 | 08:09 PM
mtber's Avatar
Nothing...
All aftermarket rc/precision injectors use a different obd1 style injector clip.
Old Sep 17, 2009 | 08:13 PM
Future50's Avatar
Got it. Thank you
8civic8
Dec 20, 2007 09:44 PM
EKB18BPR3
May 6, 2005 08:07 AM
redEH2
Jan 13, 2004 02:41 PM
Andre
Dec 20, 2003 09:38 AM
