Ok. My motor died on me again today...
Old Aug 27, 2002 | 06:58 PM
B00ST2nR's Avatar
Default Ok. My motor died on me again today...
Went to Office max to pick up some more school supplies and at the stop, my idle just sunk below 0 and the motor died. Had to start her up again and pressed the peddle a couple times...
Is this because I'm running to rich? My idle isn't quite smooth. When I start the car when its cold, the idle starts around 1800rpm then gradually gets down to 1200rpm, then when i drive it, it idle's around 700rpm or so.
It stays there most of the time, but sometimes it shoots back up to around 1200rpm then back to 700rpm, and sometimes (Like today), it just drops and my motor dies. WTF!?
Oh yea, and when it idles at 700rpm, its smooth... then once in a while the car shakes while the rpm is still steady. It keeps shuddering for awhile. Why is this?
Please help out folks...
Old Aug 28, 2002 | 06:13 AM
B00ST2nR's Avatar
Default Re: Ok. My motor died on me again today... (Skunk2nR)
Anyone?
Old Aug 28, 2002 | 07:18 AM
vtec.dc2's Avatar
spark plugs, distributor rotor - may not be the source of problem - but having these fresh helps at low rpms. when was the last time you checked/replaced these?
Old Aug 28, 2002 | 07:43 AM
bloopie's Avatar
Default Re: Ok. My motor died on me again today... (vtec.dc2)
Could be the ignitor in your dizzy.. check it out.. I had the same problem... sometimes it would run fine, but in the middle of nowhere it would die.. then start right back up fine and maybe die and then not want to start....
Old Aug 28, 2002 | 02:16 PM
B00ST2nR's Avatar
Well, my car is still pretty new. I barely drive my GS-R so it only has 9000 miles on it, so I'm guessing they're still good...
H22ARunninHard
Aug 14, 2007 01:33 PM
kim_2_da_chee
Mar 2, 2005 12:02 AM
B00ST2nR
Sep 5, 2002 03:37 PM
AnythingTypeR
Jun 4, 2002 08:28 PM
