Need help 91 Accord
Old Sep 17, 2009 | 07:28 AM
angelsf22's Avatar
New User
Default Need help 91 Accord
I need Help, pictures below are what I'm missing, can anyone tell me what I'm missing. I think the plug in an 02 sensor but the others I'm not sure. Any help is good. Also I've been reading threads and it Most of them say that F22A1's are not V-TEC. Why is that?
Thank You.
Old Sep 17, 2009 | 08:15 AM
HONDAPARTSMANMIKE's Avatar
Default Re: Need help 91 Accord
the last pic is o2 sensor wire connector secondary possibly
Old Sep 17, 2009 | 02:52 PM
amateur_guy-cb7's Avatar
VTEC - Variable Valve Timing and Lift Electronic Control
i think the question you want to ask is between DOHC VTEC and SOHC VTEC
DOHC- Double OverHead Camshaft
SOHC - Single OverHead Camshaft
im not positive but im pretty sure you have a H22A block and head
the H22a uses SOHC VTEC
its not a F22a
Old Sep 17, 2009 | 05:40 PM
miller9779's Avatar
^ retard
Old Sep 17, 2009 | 11:04 PM
Originally Posted by miller9779
^ retard
like i said, im not sure
about any of it really
Old Sep 18, 2009 | 08:41 AM
joc1394's Avatar
Here is my take on this.
The 90-93 Accords came with F22a motors in them, which are not VTEC motors, just standard SOHC 16-valve engines. My family has two of these CB7 Accords (I've got a '92 EX with an F22a6 and my father has a '91 LX with an F22a1) and it does look very much like the engine bay of a typical 90-93 Accord. However, it would appear that you at least have the VTEC head and quite possibly the entire VTEC motor from another Honda swapped into your car. Hopefully someone else on this site can help you identify which engine you have, all I can do is speculate that it is an H22 or H23 series motor.
In other words, you do not have the stock engine in your car (F22a_) and the other threads are correct in saying that the F22a1 is a non-VTEC motor.
Old Oct 20, 2009 | 01:20 PM
miller9779's Avatar
i think its an f22a4 out of a newer accord
Old Oct 20, 2009 | 02:10 PM
jdmwannabee's Avatar
+1 looks like a f22b2 head on the stock block.
reason being is head looks to be in fairly good condition, and block looks shitty.
shackler
Aug 16, 2007 02:28 PM
91jdmcrx
21
Feb 20, 2007 03:52 PM
envious_accord
May 15, 2006 07:26 AM
4g4drb17
Oct 27, 2004 03:42 AM
RobertMcDonald
Aug 25, 2002 04:09 PM
