starting problem with EF civic
91 civic hatchback, D15b
stock
so when im driving for a long(er) period of time and turn off my car, it wont just start back up. sometimes i have to wait like 2-6 minutes for it to start up again. you can hear it trying, it just wont turn over.
i open the hood and sit for a little, and it will fire right up.
want to figure out the problem before it starts to grow/get any worse.
thanks
stock
thanks
getting a CEL? i would be willing to bet you have a code 16 (fuel injectors)it is a very common problem with dpfi do an mpfi swap and it will completly alleviate the problem if that is indeed it.
or i guess you could try some injector cleaner or replace the injectors. the injector cleaner is more or less a temporary fix and new injectors may eventually have the same problem.
