fluxating oil psi...??
i have a b18a1 swapped into my crx and this is my 3rd motor in this car all 3 being b18a1's....everyone have had oil pressure that moves around when the car is at idle the oil psi is around 20-25 psi and when the car is under load (reving up) the oil psi goes to 60-65psi and stays there till engine goes to idle. is this a common problem with these engines or am i jus that unlucky that i got 3 with bad oil psi in a row! also is it safe to drive like this?
it scares me when it idles and drops around 20 psi.... and the last 2 motors i had wiped rod bearings within a month but then found my computer was puttin wayyyyyyy to much fuel into the motor and turnin my oil to gas pretty much....so i just wanted to see if the oil psi moving affect the motor when it blew up
JDMB20TDA
Aug 20, 2006 07:39 PM
boosted_zc
May 30, 2004 01:50 AM
