First Start up..
Old Sep 16, 2009 | 04:24 PM
91EF919's Avatar
Default First Start up..
Ok my build is finally done. I have a 99 ls in my ef hatch. I just rebuilt the ls head with a semi port and polish, 3 angle valve job, crower valve springs and retainers, crower 404's. My tuner told me to start it and let it idle for a little bit on the stock ecu, just dont give it gas. I started it and everything seemed fine. He gave me the ecu with the chip inside already so when he comes over it would be ready for him so it is basically a stock pr4 ecu just with a chip that hasn't been chipped yet. I know i need a tune before i drive the car i am not going to drive the car untuned. My question is My car is smoking a lot from the exhaust is this normal because it is probably running really rich or lean. I am just scared something else might be wrong and i hope not.
Old Sep 16, 2009 | 04:41 PM
shawn_crx's Avatar
Default Re: First Start up..
what color smoke....
Yep.. when I did mine build i let it idle for 30 mins.
Old Sep 16, 2009 | 04:51 PM
91EF919's Avatar
white smoke i didn't let mine idle for that long. And the idle is really high on idle its like at 1500. I think it smokes cuz its untuned and the ecu is like spazzing out lol
Old Sep 16, 2009 | 04:55 PM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
White smoke typically is coolant being burned. This is NOT normal on engine start-up. Also when you are first starting a motor it is not normal to let the car idle for "30 minutes". Please rethink your process.
Old Sep 16, 2009 | 05:21 PM
91_ef_hb's Avatar
did you check your head gasket.. might or blown it or not put on right..
Old Sep 16, 2009 | 05:24 PM
thirty5hertz's Avatar
Sound just like a head gasket.
Old Sep 16, 2009 | 06:09 PM
martn53's Avatar
i just had my head rebuilt and it also smoked a buttload, but after awhile it took off,but i drove it for a while too
Old Sep 16, 2009 | 06:50 PM
91EF919's Avatar
Its a brand new head gasket and i am pretty sure i put it on right. No one thinks its the bad untuned ecu? I also have a check engine light on even when the 02 sensor is plugged in. I think the ecu is all f'ed up ima get the car tuned this weekend.
Old Sep 16, 2009 | 07:02 PM
91EF919's Avatar
and it doesn't smoke like soo much its just a little bit. I havn't gave it gas yet cuz i was told not to give it gas on the stock ecu. I still dont know y it revs so high.
Old Sep 16, 2009 | 07:11 PM
DO IT ON ALL FOURS
Unless you have condensation in your exhaust white smoke only comes from water. Coolant has water in it so therefore it would be burning coolant. Pull your plugs and read them if you are not sure.
The tune would not cause your engine to pour out white smoke... only black if anything...
Old Sep 16, 2009 | 07:14 PM
91EF919's Avatar
ok thanks
Old Sep 17, 2009 | 02:26 PM
91EF919's Avatar
here is a vid of an teg with the same setup and in this video my exhaust smokes exactly like this.
http://www.youtube.com/watch?v=k2aZdjj-uok
Old Sep 17, 2009 | 02:32 PM
johnnyonth3spot's Avatar
That does'nt look like white smoke thats fuel burning.
Old Sep 17, 2009 | 03:32 PM
91EF919's Avatar
ok good because that is what mine looks like. K so i guess i dont have white smoke. I knew it was ecu its probably running super rich right now. Thanks everyone
Old Sep 17, 2009 | 03:54 PM
ketchup's Avatar
that car sounds like shiet.
Old Sep 17, 2009 | 04:10 PM
jayshf's Avatar
video sounds like you need to adjust your valves. dose it smell like gas or do you have an AFR gage? if you do is it running rich
Old Sep 17, 2009 | 04:12 PM
ketchup's Avatar
that aint his car. he was using the video to show us what the smoke coming out of his car is similar to.
Old Sep 17, 2009 | 04:27 PM
91EF919's Avatar
yea thats not my car. Like what ketchup said it is similar to my smoking. Its running so rich i am guessing. I got a CEL and its idling at like 1500. I need to get my tune soon. It sucks having my car down. Ima get my car tuned probably this weekend.
JoelAndrew
Oct 5, 2011 10:07 AM
92civtegra
Mar 31, 2009 06:27 AM
Turbo_y8
May 5, 2006 10:30 PM
blykins
Apr 30, 2004 03:35 AM
Angry Joe
Aug 6, 2002 07:10 PM
